Problem with Binding datagrid  into code behind
1253
02-12-2014 06:53 AM
Abdoulaye_Djibril_MademouDIALL
Hi everyone,
i have a problem with binding datagrid into code behind
indeed i have the code below
               dataGrid1.Columns.Clear();
                for (int i = 0; i < mylistChamp.Count; i++)  //mylistChamp is a  liste of the fields in the featurelayer
                    DataGridTextColumn dgc = new DataGridTextColumn();
                    String c = mylistChamp;
                    dgc.CanUserSort = true;
                    dgc.SortMemberPath = mylistChamp;
                    dgc.Binding = new System.Windows.Data.Binding("Attributes");            // The line with the problem
                    dgc.Header = mylistChamp;
                    dataGrid1.Columns.Add(dgc);
the code below can not work but if i replace the line: dgc.Binding = new System.Windows.Data.Binding("Attributes")
with dgc.Binding = new System.Windows.Data.Binding("Attributes[NAME]") where NAME represent the Fields the code work well
Please Someone Can Help me ?
SheridanNava
Have you try just binding the name of the field?  System.Windows.Data.Binding("field") or System.Windows.Data.Binding(c) in your case?
thanks Snava for the reply ,
in fact i try binding System.Windows.Data.Binding(c) but c represent the fields because somewhere in the code i write
c=mylistChamp;// mylistChamp represent the liste of all the fields in my featurelayer
is it clear ??
it's good I found
i write dgc.Binding = new System.Windows.Data.Binding("Attributes[" + c + "]") instead of i  dgc.Binding = new System.Windows.Data.Binding("Attributes["") .
Thanks for the help
