Printing or Exporting TextSymbol
1544
04-25-2013 11:36 AM
NicholasGross
I'm trying to give users the ability to make text notations on the map and print them out. I can get the text on the map without any issues using either a text symbol or a marker symbol with a textblock in the template. But, in either case, when using the print task they both just show up as a point graphic on the final document.
Is there any way to allow printing of markup text?
JohanCarlsson
JohanCarlsson
I'm not sure this will help, but try changing the RendererTakesPrecedence setting.
http://resources.arcgis.com/en/help/silverlight-api/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.Gra...
RobertBorchert
Honored Contributor
Make sure the users all have the gis fonts on their computers and that your printers are enabled for True Type Fonts.
Are you printing direct to a printer or to a PDF.
Try exporting the print as a PDF.  In the format tab select Embed All Document Fonts.
Is there anyway to allow printing of markup text?
NicholasGross
I think that did the trick for the text symbol. Thank you!
