Print Task - text overkill
1001
02-19-2014 11:37 AM
DaveOrlando
Can anyone tell me if there is a way to throttle down the re-sampling that occurs when PrintTask is executed. It is producing way too many text elements per object.
Have a look at the PDF attached. There should only be one brown and one blue text element per polygon
I can understand what it's doing (much like when we cache), but the result is a little overkill and I'm wondering if there is any setting that can be changed to avoid this.
I have tried the different MapOptions with different extents and scale, but the results are the same regarding too much text.
Dave
DaveOrlando
Here is another example, using the 'MAP_ONLY'
I should clarify, the brown are polygon 'labels', not text or anno, and I can assure you, there is only one label of each on the screen.
surely I can't be the first to run into this.........
any help would be appreciated, thanks
