Polygons crossing the 180 meridian
11333
5
01-28-2013 05:27 AM
TraceyRichvalsky
I am trying to display a set of polygons (rectangles) that cross the 180 meridian.  However instead of showing up as crossing the 180 meridian, they all show up as a very wide rectangle that goes the "other way" around the map.  It's as if east and west are reversed when the polygons cross the dateline.  Is this a known issue?  I currently have v2.4 of the API.  Is this fixed in a later version if it is an issue in 2.4?
DominiqueBroux
Esri Frequent Contributor
How is created your polygon?
If all X coordinates of your polygon are between -180 and 180, your polygon will not cross the date line (except if your polygon has been normalized and contains multi rings).
TraceyRichvalsky
Say I make a polygon from the following points:
NE point: Lat 45, Lon -178 (east of the meridian)
SE point: Lat 40, Lon -178
SW point: Lat 40, Lon 176 (west of the meridian)j
NW point: Lat 45, Lon 176
NE point: Lat 45, Lon -178 (to join to the original point and complete the polygon)
It should cross the meridian, but instead it goes the other way around the globe.
DominiqueBroux
To cross the meridian, you need either to use X coordinates < -180 or > 180, or you need to create 2 rings for your geometry.
In your case:
NE point: Lat 45, Lon 182 (east of the meridian)
SE point: Lat 40, Lon 182
NE point: Lat 45, Lon 182 (to join to the original point and complete the polygon)
Then you can normalize that geometry and you'll get 2 rings.
TraceyRichvalsky
Thank you - that helps a great deal!
Could you please explain your last statement though?  "Then you can normalize that geometry and you'll get 2 rings."  I'm not sure how to do that or what effect it would have.  Thanks!
DominiqueBroux
The NormalizeCentralMeridian method transforms a geometry to stay within the -180/+180 extent.
In case of a polyline or polygon crossing the dateline, the result is a polyline with 2 paths (and respectively a polygon with 2 rings), one close to -180 and the other close to +180 longitude.
You can look at the ShowMapExtent sample which uses the method NormalizeCentralMeridian.
Most generally you don't need to normalize a geometry for working at client side. More useful for the storage at server side.
