Polygon points with googlemap is different
1027
10-21-2012 05:40 AM
JulieBiju
Dear Friends,
I need urgent help for the following issue.
I developed one module for Drawing the polygon.These polygon points I am saving to the DB.Everything is working fine with the following URL
<esri:ArcGISTiledMapServiceLayer ID="StreetMapLayer" Url="http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer" />
Now same code I am trying to use with Googlemap.But the longitude and latitude of the same place giving different.
For eg:When i draw a polygon on ESRI_StreetMap_World_2D/MapServer .The points like 58.25,23.225 58.232,24.89 58.35,23.225
When I draw a polygon on Googlemap withthese same location,The points are 2704315.97807635,6496765.39170823 2704330.31001916,6496775.09562783,  2704315.97807635 6496765.39170823
Y it is getting the values like this.I am very confused.Can anybdy help me to solve my issue?PLEASEEEE
    End Sub
    Private Sub MyDrawObject_DrawComplete(ByVal sender As Object, ByVal args As ESRI.ArcGIS.Client.DrawEventArgs)
        If TypeOf args.Geometry Is Polygon Then
            Dim cntpoints As Integer = DirectCast((args.Geometry), Polygon).Rings(0).Count
            If (cntpoints <= 2) Then Exit Sub
            Dim points As PointCollection = DirectCast((args.Geometry), Polygon).Rings(0)
            'Save the points
 For Each mapPoint As MapPoint In points
                ''''''''''''''''''Save data to DB
                VID = VID + 1
                Dim ProxySavePoly As ComboLoadClient = New ComboLoadClient()
                AddHandler ProxySavePoly.SavePolyGonIDCompleted, AddressOf client_SavePolyGonIDCompleted
                ProxySavePoly.SavePolyGonIDAsync(" VALUES(" & PID & "  ," & VID & "," & (mapPoint.Y) & "," & (mapPoint.X) & ", " & _
            " " & fahrid1 & ",'" & Geofencename & "','" & Geofencedesc & "','" & DateAndTime.Now & "')")
        End If
DominiqueBroux
Esri Frequent Contributor
It's  a spatial refrence matter.
If your map is using web Mercator coordinates (depending on your base map), you can transform these coordinates to geographical coordinates y using the WebMercator.ToGeographic method.
JulieBiju
Thank u so much. Ineed your help based on the code I pasted here with.I need to convert (mapPoint.Y) and (mapPoint.X)
How can i do this?PLease give me a help....
            'Save the points
                VID = VID + 1
        End If
