PicutreMarkerSymbol does not work but SimpleMarkerSymbol does
1008
10-22-2010 01:53 PM
TerryGiles
I thought I'd seen a fix for this last week in the forums but can't find it today!  I'm trying to add a graphic to a graphics layer using an image defined in Resources of my user control but if I use a PictureMarkerSymbol nothing draws whereas a SimpleMarkerSymbol does.  The ESRI Identify sample uses a PictureMarkerSymbol so I know it's possible.
I have a user control that a user can enter a Lat-Long and the map will zoom to it and (should) add a graphic at the local they entered.  I'm wondering if it's a location issue - my control is /UserControls/ZoomToXY and references a PNG in /UserControls/Images as the source for the PictureMarkerSymbol.  I've tried putting the PNG up a level in the /Images folder but that doesn't seem to solve the problem either.
Anyone know what I'm missing?  Thanks, Terry
XAML for resources:
    <Grid x:Name="LayoutRoot" Background="Transparent">
        <Grid.Resources>
            <esri:PictureMarkerSymbol x:Name="DefaultPictureSymbol" OffsetX="13" OffsetY="22"
                 Source="/Images/IdentifyMapIcon.png"  />
            <esri:SimpleMarkerSymbol x:Name="SMStest" Color="Red" Size="12" />
        </Grid.Resources>
Code behind:
            //add graphic to map
            GraphicsLayer graphicsLayer = (GraphicsLayer)_Map.Layers[_GraphicsLayer];
            graphicsLayer.ClearGraphics();
            //this does not work
            Graphic graphic = new Graphic() { Geometry = ptMapPoint, Symbol = DefaultPictureSymbol };
            graphicsLayer.Graphics.Add(graphic);
            //using a SimpleMarkerSymbol works
            Graphic graphic2 = new Graphic() { Geometry = ptMapPoint, Symbol = SMStest };
            graphicsLayer.Graphics.Add(graphic2);
dotMorten_esri
Esri Notable Contributor
Note that "/Images/IdentifyMapIcon.png" is relative to where the .xap file is, not where the hosting html file is.
TerryGiles
Hi Morten,
Thank you, chaning the path in the XAML fixed it.
        <Grid.Resources>
            <esri:PictureMarkerSymbol x:Name="DefaultPictureSymbol" OffsetX="12" OffsetY="24"
                 Source="../UserControls/Images/IdentifyMapIcon.png"  />
        </Grid.Resources>
I'm still a little confused as to how path references work in the XAP. Why does it need the "../UserControls" in the source string - the ZoomToXY.xaml is in the UserControls folder but neither "/Images/IdentifyMapIcon.png" nor "./IdentifyMapIcon.png" work in the controls xaml but it did work in code -
                  //Symbol = DefaultPictureSymbol
                  Symbol = new PictureMarkerSymbol()
                        { Source = new BitmapImage(new Uri("Images/IdentifyMapIcon.png", UriKind.Relative)),
                          OffsetX=12, OffsetY=24 }
Thanks again, Terry
dotMorten_esri
The difference lies in whether the xaml is parsed as part of the page (where relative makes sense), or whether it's a piece of code that could have been executed from anywhere.
