Performance problem when I import my ArcGIS Server's layer
944
06-06-2011 06:55 PM
shinjaekang
I'm testring a GIS screen using ArcGIS API for Microsoft Silverlight/WPF.
My test environment is like this:
- ArcGIS API for Microsoft Silverlight/WPF 2.1 or 2.2
- ArcGIS Server 9.3.1
- 1 local shapefile
- Microsoft Visual Studio 2010
This is my step:
1. Install ArcGIS API for Microsoft Silverlight/WPF
2. Make a new service and publish my local polygon shapefile. Rest information of my service is like this
Test (MapServer)
View In: ArcMap ArcGIS Explorer ArcGIS JavaScript Google Earth
View Footprint In: Google Earth
Service Description:
Map Name: Layers
Layers:
TestLayer (0)
Description:
Copyright Text:
Spatial Reference: 32748
Single Fused Map Cache: false
Intial Extent:
XMin: 655999.922725362
YMin: 9198575.66869691
XMax: 899003.860308017
YMax: 9346219.46839192
Full Extent:
XMin: 698264.223300862
YMin: 9198411.25466607
XMax: 849176.514313842
YMax: 9346055.05436108
Units: esriMeters
Supported Image Format Types: PNG32,PNG24,PNG,JPG,DIB,TIFF,EMF,PS,PDF,GIF,SVG,SVGZ
Document Info:
Title: Test
Author: test
Comments:
Subject:
Category:
Keywords:
AntialiasingMode: None
TextAntialiasingMode: None
Supported Interfaces: REST SOAP
Supported Operations: Export Map Identify Find Generate KML
3. Create new WPF application project in Visual Studio 2010
4. Design GIS screen like follows
<esri:Map x:Name="Map">
<esri:ArcGISTiledMapServiceLayer ID="WorldShadeReliefLayer" Url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Shaded_Relief/MapServer" />
<esri:FeatureLayer ID="MyLayer" Url="http://localhost/ArcGIS/rest/services/Test/MapServer/1" Color="LightGray" />
</esri:Map>
Questions
When I run my application, my feature layer is displayed well, but performance is significantly downed when I move screen.
I guess I miss some configuration in my service. Because, when I import my layer in ArcGIS Explorer, it displays very smoothly.
How can I re-config my service setting for improve performance likes ArcGIS Explorer?
Or, Do have any ways of loading local shapefile and display to GIS Screen? I already tested by esricontlib but that library spends a lot of time to load my shape file.
Sorry for very basic question. T.T
DominiqueBroux
Esri Frequent Contributor
It might happen that your polygons contain a lot of points and that you might enhance the performances by generalizing the geometry.
To do that you can set the MaxAllowableOffset property of your feature layer (the value depending on your spatial reference and your polygon scale, you can try first with a big value e.g. MaxAllowableOffset="5000" and then adapt it).
