Passing Data To/From Application
977
10-06-2010 08:53 AM
PaulHuppé
I have a small Silverlight map application that I call from an ASP.NET web page using using the "object" tag as follows:
        <object data="data:application/x-silverlight-2," type="application/x-silverlight-2" width="590" height="300">
    <param name="source" value="ClientBin/MapViewer.xap"/>
    <param name="onError" value="onSilverlightError" />
    <param name="background" value="white" />
    <param name="minRuntimeVersion" value="4.0.50401.0" />
    <param name="autoUpgrade" value="true" />
                  <param name="initParams" value="<%= lang %>" />
I have figured out how to pass parameters to the application using the "param" parameter of the "object" tag.  Now, I need to do the reverse.  I need to have the Silverlight application either set the value of a textbox for example, on the ASP.NET parent page, or find some other way to send data back to the parent page.  As anyone done this before?
Paul
DanielWalton
You can do it using Javascript and Silverlight's HtmlPage class. Here is a blog post explaining how to do it:
http://geekswithblogs.net/PeterTweed/archive/2009/08/08/html-bridge---silverlight-javascript-interop...
PaulHuppé
Wow, great article. Exactly what I needed.
Paul
