Obtaining Results from a IdentifyResult
1132
02-17-2011 05:03 AM
jonataspovoas
I'm developing an application, and in it i get information to populate a DataGrid from an Identify Function.
My problem is that the information needs to be in a very specific order, and i'm having trouble to obtain it.
I started studying the IDictionary and found, hoping to find out my salvation, but here's what i got so far:
public class DataItem
 public string Title { get; set; }
 public IDictionary<string, object> Data { get; set; }
//This is called after the results are found!
public void getIdentifyResults(List<IdentifyResult> results)
 _dataItems = new List<DataItem>();
 linhaDeObservações = new List<string>();
 if (results != null && results.Count > 0)
  IdentifyComboBox.Items.Clear();
  foreach (IdentifyResult result in results)
   /* there can be more than oe result, each with several
    * lines, which i must select a few.
   Graphic LineCatcher = new Graphic();
   /* The following line should get lines by it's key (like "number", for example)
    * and will be repeated several times.
   LineCatcher.Attributes.Add(result.Feature.Attributes.Where(/*Don't know what to put here*/);
   string title = result.Value.ToString() + " (" + result.LayerName + ")";
   _dataItems.Add(new DataItem()
    Title = title,
    Data = LineCatcher.Attributes
   IdentifyComboBox.Items.Add(title);
  IdentifyComboBox.SelectedIndex = 0;
Anyone can help me?
JenniferNery
What do you mean by "in specific order"? Do you mean sorted results or sorted field names?
jonataspovoas
Sorted Results.
the results come in an order and i need to change it.
Like:
   Key | Value
Cell number | 7897-7978
 Name | Joseph Climber
      Number | 129890
          Key | Value
     Number | 129890
I need sort the lines in an order that is neither alphabetical nor numeric
jonataspovoas
I'm replying my reply to say that i finaly did it!
I'm posting here the solution:
MainPage.xaml
<UserControl x:Class="DataOrdering.MainPage"
    xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
    xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
    xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
    xmlns:slData="clr-namespace:System.Windows.Controls;assembly=System.Windows.Controls.Data"
    mc:Ignorable="d"
    d:DesignHeight="600" d:DesignWidth="800">
    <Canvas x:Name="LayoutRoot" Background="White">
        <slData:DataGrid x:Name="dadios" AutoGenerateColumns="False" HeadersVisibility="Column" Background="White" IsReadOnly="True" HorizontalScrollBarVisibility="Visible" Margin="8,15,-27,6" Height="165" Canvas.Left="4" Canvas.Top="37">
            <slData:DataGrid.Columns>
                <slData:DataGridTextColumn Width="Auto"  Binding="{Binding Key}" Header="Keys" FontWeight="Bold"/>
                <slData:DataGridTextColumn Width="Auto" Binding="{Binding Value}" Header="Values" />
            </slData:DataGrid.Columns>
        </slData:DataGrid>
    </Canvas>
</UserControl>
MainPage.xaml.cs
using System;
using System.Collections.Generic;
using System.Linq;
using System.Net;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Documents;
using System.Windows.Input;
using System.Windows.Media;
using System.Windows.Media.Animation;
using System.Windows.Shapes;
using System.Collections;
namespace DataOrdering
    public partial class MainPage : UserControl
        public MainPage()
            InitializeComponent();
            addResults();
        private void addResults()
            IDictionary<string, object> dataDictionary = new Dictionary<string, object>();
            dataDictionary.Add("Test", "Testado");
            dataDictionary.Add("ID", 10);
            dataDictionary.Add("id", "hhotbh");
            dataDictionary.Add("ThisGoesOnTop", "Qqr coisa");
            dataDictionary.Add("ThisGoesOnBottom", "oiyggfq");
            dadios.ItemsSource = order(dataDictionary);
        public IDictionary<string, object> order(IDictionary<string, object> dataDictionary)
            IDictionary<string,object> destiny = new Dictionary<string,object>();
            Dictionary<string, object> source = dataDictionary as Dictionary<string, object>;
            object value;
            if (source.TryGetValue("ThisGoesOnTop", out value)) destiny.Add("ThisGoesOnTop",value);
            if (source.TryGetValue("ID", out value)) destiny.Add("ID", value);
            if (source.TryGetValue("Test", out value)) destiny.Add("Test", value);
            if (source.TryGetValue("id", out value)) destiny.Add("id", value);
            if (source.TryGetValue("ThisGoesOnBottom", out value)) destiny.Add("ThisGoesOnBottom", value);
            return destiny;
JenniferNery
Ahh, you mean you want the results displayed in certain order according to their field names (not their values), where if results came back with Cell > Name > Number, you want to change the order to Number > Name > Cell.
In this sample: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#Identify, you need to modify ShowFeatures() where Data can no longer be set directly to feature.Attributes.
Without any change to this sample, click on Denver. For simplicity let's look at only 3 fields. Notice the order of these 3 fields: ObjectID > NAME > STATE_NAME. If you want to change the order in which they appear, you will need something like this to force them to be in a certain order.
private IDictionary<string, object> OrderedAttributes(IDictionary<string, object> source)
 IDictionary<string, object> result = new Dictionary<string, object>();
 List<string> orderedFields = new List<string>() { "STATE_NAME", "NAME", "ObjectID" };
 foreach (var f in orderedFields)
  if (source.ContainsKey(f))
   var item = source;
   result.Add(f, item);
 return result;
