Noaa NowCoast WMS layers
6911
08-31-2011 12:22 PM
MichaelKohler
I've been trying to add a WMS layer from NOAA's NowCoast data from here http://nowcoast.noaa.gov/help/mapservices.shtml?name=mapservices
I've been successful in adding it to a mxd and publishing it and consuming it as a ArcGISDynamicMapServiceLayer.
I want to be able to use a single layer from the WMS server as a WmsLayer. I've used the radar example from the silverlight examples but haven't been able to get this to work.
It just comes up empty.
for testing, I'm using
<esri:WmsLayer ID="GOES IR"
                           Url="http://nowcoast.noaa.gov/wms/com.esri.wms.Esrimap/obs"
                           ProxyUrl="http://serverapps.esri.com/SilverlightDemos/ProxyPage/proxy.ashx"
                           Layers="RAS_GOES_I4" Version="1.1.1"
                           Opacity="0.7" Visible="True"  />
Is there any way to add the layer from my map service without using DynamicMapService or can someone point me to the propper way to add this as a WMS layer.
Thanks!
DeminHu
one week ago, I tried to use nowcoast WMS layers,  it didn't work as we expected, it was to slow.
Here is some real-time hurricane  layer links,  you may want to take a look, I like it better.
http://www.arcgis.com/home/item.html?id=4a9b65e79ea045ffbd1b6087674ee78b
Web Cameras
Active Hurricanes:
http://esrilabs1.esri.com/ArcGIS/rest/services/LiveFeeds/Hurricane_Active/MapServer
Stream Gauges:
http://esrilabs1.esri.com/ArcGIS/rest/services/LiveFeeds/StreamGauge/MapServer
NOAA Storm Reports:
http://esrilabs1.esri.com/ArcGIS/rest/services/LiveFeeds/NOAA_storm_reports/MapServer
NOAA Wind Speed / Direction:
http://esrilabs1.esri.com/ArcGIS/rest/services/LiveFeeds/NOAA_METAR_current_wind_speed_direction/Map...
USGS Stream Gauges and Weather Stations:
http://rmgsc.cr.usgs.gov/ArcGIS/rest/services/nhss_usdata/MapServer
Hurricane Wind Force Probability:
http://esrilabs1.esri.com/ArcGIS/rest/services/LiveFeeds/NOAA_Current/MapServer
US Precipitation Radar:
http://atlas.resources.ca.gov/ArcGIS/rest/services/Atmosphere_Climate/RIDGE_Precip_Radar/MapServer
US Weather Watches & Warnings:
http://rmgsc.cr.usgs.gov/ArcGIS/rest/services/nhss_weat/MapServer
Surface Wind Velocity (NOAA):
http://nowcoast.noaa.gov/wms/com.esri.wms.Esrimap/analyses
NOAA GOES Visible Image:
National Data Buoy Center:
http://www.arcgis.com/sharing/content/items/cbbaec1f03cb4d788ef6319c391a1615/data
Topographic:
http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer
