New attribute binding
1390
09-06-2013 10:45 AM
JeffRogholt
Not every graphic in our feature dataset has geometry and I'd like to add a column to the datagrid to identify this.  Before assigning the feature layer to the datagrid graphics layer, I loop thru the graphics and add an attribute called "HasShape" and assign a value of "True" or "False" (string data type not boolean).
When I debug my code, the attribute list includes "HasShape" but this is the exception I get when I bind the data to the grid:
'HasShape' property not found on 'ESRI.ArcGIS.Client.Toolkit.DataSource.TempTypeMinus2021084955'
Here's the code I'm using to add the attribute:
Dim lyr As New ESRI.ArcGIS.Client.FeatureLayer lyr = CType(Mainpage.MyMap.Layers("MyFeatureLayer"), ESRI.ArcGIS.Client.FeatureLayer)  For Each item As ESRI.ArcGIS.Client.Graphic In lyr.Graphics     If item.Geometry Is Nothing Then       item.Attributes.Add("HasShape", "False")        Else       item.Attributes.Add("HasShape", "True")     End If Next  Mainpage.MyDataGrid.GraphicsLayer = Mainpage.MyMap.Layers("MyFeatureLayer")
I do NOT auto generate the datagrid's columns so here is my code to add the "HasShape" column:
        Dim col As New DataGridTextColumn         col.Binding = New Windows.Data.Binding("HasShape")         col.Header = "Has Shape"         col.Width = New DataGridLength(80.0)         col.IsReadOnly = True         MyDataGrid.Columns.Add(col)
Please let me know if this is possible or maybe there's a better way to identify if there's a geometry.
Jeff
DenisT
My fault, just noticed you were using FeatureDataGrid.
In that case you can add your new Field description to lyr.LayerInfo.Fields.
Not sure if there will be any side-effects during feature layer editing.
DenisT
Try the following code:
col.Binding = New Windows.Data.Binding("Attributes[HasShape]")
You can bind to the Geometry itself but use a custom IValueConverter implementation. Then the geometry changes will be tracked automatically.
DenisT
