Need help with  the School Locator application downloaded from ArcGIS Resource center
893
01-21-2011 01:35 PM
JamesWalker
I am having a little difficulty using a Silverlight program called "School Locator" I downloaded from the ArcGIS Resource center.
http://help.arcgis.com/en/webapi/silverlight/gallery.html
http://coolapps.cybertech.com/AppGallery/school_locator.aspx
When I run the program on my desktop using Visual Studio it deploys correctly using the sample data on the ESRI server that the program comes with, I tried replacing the school layer with schools for my district in a schematically identical feature class but they did not display. So I took a copy of the ESRI sample data and created a web service on my server and tested it independently, and it worked. But when I plugged the URL to my server into the silver light program I still get no schools.
This is the original code from the Web.config part of the program.
  <!-- SERVICE URLs (Public Schools,Boudaries and Other Services) -->
    <add key="HighBoundary" value="http://184.72.240.25/ArcGIS/rest/services/School_Locator/MapServer/1"/>
    <add key="MiddleBoundary" value="http://184.72.240.25/ArcGIS/rest/services/School_Locator/MapServer/2"/>
    <add key="ElementaryBoundary" value="http://184.72.240.25/ArcGIS/rest/services/School_Locator/MapServer/3"/>
    <add key="PublicSchools" value="http://184.72.240.25/ArcGIS/rest/services/School_Locator/MapServer/0"/>
    <add key="EmailService" value="http://184.72.240.25/ArcGIS/rest/services/CoolAppsFeatureServices/FeatureServer/17"/>
    <add key="CommentService" value="http://184.72.240.25/ArcGIS/rest/services/CoolAppsFeatureServices/FeatureServer/16"/>
and this is changeing the one piece of data to call the copy on my server, which hapens to be on an internal network.
    <add key="PublicSchools" value="http://appsutil/ArcGIS/rest/services/School_Locator/MapServer/0"/>
Does anyone know why this isn�??t working?  Dose the URL need to match something else somewhere in the program?  I am new to Silverlight development, hopefully I am missing something simple that can be easily fixed.
Thank you for taking the time to help me
James Walker
Garland Independent School District
JenniferNery
You can try to troubleshoot the layers that do not display by reading this blogpost: http://blogs.esri.com/Dev/blogs/silverlightwpf/archive/2009/08/24/Troubleshooting-blank-layers.aspx
