FeatureLayer and map editor
1423
01-21-2011 02:13 AM
jonataspovoas
I'm trying to build a online map editor, so i started researching about the FeatureLayer, but i didn't find much info about it.
Can anyone point me a direction, some links or maybe samples to help me understand how it works and how to make a map editor?
Thanks!
by Anonymous User
Not applicable
Here are some links you may find helpful.  I would check out the ArcGIS API for Microsoft Silverlight / WPF samples page.
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm
From there explore the category on Feature Layers and Editing.
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#FeatureLayerSimple
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#ToolkitEditorWidget
Hope this helps.  Also check out this post showing a little about code behind editing.  While it's not an official sample, it may help as you build out your map editor.
http://forums.arcgis.com/threads/19327-Editing-from-the-code-behind
Regards,
Doug Carroll, ESRI Support Services SDK Team
http://support.esri.com/
