Need help with address locator
1183
04-05-2010 07:13 AM
DonFreeman
Hi there, I could use some help getting my address locator to work with my silverlight page. It seems to work OK with a straight /NET page but I'm missing something in the transfer to silverlight. Here's my code. You can tell by the comments some of the things I have tried. (Morton - The REST endpoint is now working.)
 Private Sub FindAddressButton_Click(ByVal sender As Object, ByVal e As RoutedEventArgs)
  Dim locatorTask As New Locator("http://maps.pagnet.org/arcgis/rest/services/PAGAddressLocator/GeocodeServer")
        AddHandler locatorTask.AddressToLocationsCompleted, AddressOf LocatorTask_AddressToLocationsCompleted
        AddHandler locatorTask.Failed, AddressOf LocatorTask_Failed
        Dim addressParams As New AddressToLocationsParameters()
        Dim addressDictionary As Dictionary(Of String, String) = addressParams.Address
  If (Not String.IsNullOrEmpty(Address.Text)) Then
   addressDictionary.Add("Street", Address.Text)
  End If
  'If (Not String.IsNullOrEmpty(City.Text)) Then
  ' addressDictionary.Add("City", City.Text)
  'End If
  'If (Not String.IsNullOrEmpty(State.Text)) Then
  '    addressDictionary.Add("State", State.Text)
  'End If
  'If (Not String.IsNullOrEmpty(Zip.Text)) Then
  '    addressDictionary.Add("Zip", Zip.Text)
  'End If
  locatorTask.AddressToLocationsAsync(addressParams)
 End Sub
    Private Sub LocatorTask_AddressToLocationsCompleted(ByVal sender As Object, ByVal args As ESRI.ArcGIS.Client.Tasks.AddressToLocationsEventArgs)
        Dim returnedCandidates As List(Of AddressCandidate) = args.Results
        Dim graphicsLayer As GraphicsLayer = TryCast(MyMap.Layers("MyGraphicsLayer"), GraphicsLayer)
        graphicsLayer.ClearGraphics()
        Dim _candidateList = New List(Of AddressCandidate)()
        Dim candidateListBox As New ListBox()
        For Each candidate As AddressCandidate In returnedCandidates
   If candidate.Score >= 95 Then
    _candidateList.Add(candidate)
    candidateListBox.Items.Add(candidate.Address)
    Dim graphic As New Graphic() With {.Symbol = DefaultMarkerSymbol, .Geometry = candidate.Location}
'    graphic.Attributes.Add("street", candidate.Address)
    graphic.Attributes.Add("Address", candidate.Address)
    'Dim latlon As String = String.Format("{0}, {1}", candidate.Location.X, candidate.Location.Y)
    'graphic.Attributes.Add("LatLon", latlon)
    graphicsLayer.Graphics.Add(graphic)
   End If
        Next candidate
        AddHandler candidateListBox.SelectionChanged, AddressOf _candidateListBox_SelectionChanged
        CandidateScrollViewer.Content = candidateListBox
        CandidatePanelGrid.Visibility = Visibility.Visible
        Dim pt As MapPoint = _candidateList(0).Location
        If _firstZoom Then
            MyMap.ZoomToResolution(MyMap.Resolution / 4, pt)
            _firstZoom = False
        Else
            MyMap.PanTo(pt)
        End If
        _lastIndex = 0
        candidateListBox.SelectedIndex = 0
    End Sub
DonFreeman
Whoa there. I found the problem. I had my local map overlaid on top of an ESRI national map. Apparently the zoom didn't know which map was in charge. When I removed the ESRI map it worked fine. Now the question is if there are multiple map layers, how do you tell the locator which map to use for the match and zoom?
