navigation issues
1994
5
06-30-2010 04:50 AM
LanceCrumbliss
hi all, i've got a user control (code attached) that was working just fine in the pre-RC of the API (it is in fact almost entirely built on the sample here http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#Navigation), but now will throw an error when following these steps after starting the app:
1) pressing the zoom in tool
2) using the zoom in tool to zoom in
3) pressing the pan tool
4) pressing the zoom in tool again.
and will occur at the highlighted line in the sub below
 Private Sub ToolButton_Clicked(ByVal sender As System.Object, ByVal e As System.Windows.RoutedEventArgs)
  If _bDrawObjectInitialized = False Then
   _DrawObject = New Draw(Map) With {.DrawMode = DrawMode.Rectangle, .FillSymbol = DefaultFillSymbol}
   AddHandler _DrawObject.DrawComplete, AddressOf _DrawObject_DrawComplete
   _bDrawObjectInitialized = True
  End If
  Dim Btn As Button = sender
  For Each childBtn As Button In ToolsPanel.Children
   If childBtn.Name <> Btn.Name Then
    childBtn.Background = _OriginalButtonBackground
   End If
  Btn.Background = ToggleGradient 'New SolidColorBrush(Color.FromArgb(128, 0, 255, 0))
  Dim ToolName As String = Btn.Name
        Select Case ToolName
            Case "Pan"
                _DrawObject.IsEnabled = False
                DrawActive = False
                _toolmode = "pan"
            Case "ZoomInTool"
                _DrawObject.IsEnabled = True
                DrawActive = True
                _toolmode = "zoomin"
            Case "ZoomOutTool"
                DrawActive = True
                _toolmode = "zoomout"
        End Select
 End Sub
the short version of the error is
Object reference not set to an instance of an object.
and the long one is
{System.NullReferenceException: Object reference not set to an instance of an object.
   at ESRI.ArcGIS.Client.LayerCanvas.PrepareAnimation()
   at ESRI.ArcGIS.Client.Map.beginZoomToExtent(Envelope targetExtent, Boolean skipAnimation)
   at ESRI.ArcGIS.Client.Map.zoomToResolution(Double resolution, MapPoint center, Boolean skipAnimation)
   at ESRI.ArcGIS.Client.Map.ZoomToResolution(Double resolution, MapPoint center)
   at ESRI.ArcGIS.Client.Map.ZoomToResolution(Double resolution)
   at ESRI.ArcGIS.Client.Map.Layers_LayersInitialized(Object sender, EventArgs args)
   at ESRI.ArcGIS.Client.LayerCollection.calculateLevelScheme()
   at ESRI.ArcGIS.Client.LayerCollection.LayerCollection_CollectionChanged(Object sender, NotifyCollectionChangedEventArgs e)
   at System.Collections.Specialized.NotifyCollectionChangedEventHandler.Invoke(Object sender, NotifyCollectionChangedEventArgs e)
   at System.Collections.ObjectModel.ObservableCollection`1.OnCollectionChanged(NotifyCollectionChangedEventArgs e)
   at System.Collections.ObjectModel.ObservableCollection`1.InsertItem(Int32 index, T item)
   at System.Collections.ObjectModel.Collection`1.Add(T item)
   at ESRI.ArcGIS.Client.Draw.Activate()
   at ESRI.ArcGIS.Client.Draw.OnIsEnabledPropertyChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
   at System.Windows.DependencyObject.RaisePropertyChangeNotifications(DependencyProperty dp, Object oldValue, Object newValue)
   at System.Windows.DependencyObject.UpdateEffectiveValue(DependencyProperty property, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, ValueOperation operation)
   at System.Windows.DependencyObject.SetValueInternal(DependencyProperty dp, Object value, Boolean allowReadOnlySet)
   at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value)
   at ESRI.ArcGIS.Client.Draw.set_IsEnabled(Boolean value)
   at CHFMap09.NavBar.ToolButton_Clicked(Object sender, RoutedEventArgs e)
   at System.Windows.Controls.Primitives.ButtonBase.OnClick()
   at System.Windows.Controls.Button.OnClick()
   at System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(MouseButtonEventArgs e)
   at System.Windows.Controls.Control.OnMouseLeftButtonUp(Control ctrl, EventArgs e)
   at MS.Internal.JoltHelper.FireEvent(IntPtr unmanagedObj, IntPtr unmanagedObjArgs, Int32 argsTypeIndex, String eventName)}
DominiqueBroux
Esri Frequent Contributor
Looks the same error than http://forums.arcgis.com/threads/7242-Exception-on-Draw.IsEnabled-true
From my tests, it could happen more frequently if SnapToLevels map property is set to true.
Is it your case?
If it is, a workaround might to set SnapToLevels to false.
LanceCrumbliss
Is it your case?
hm, yes...it does seem to only happen when SnapToLevels is true.  is this a bug?  again, this didn't happen with the previous build of the API.  it just started happening with the RC.
i'd rather not have to settle on always having SnapToLevels set to true.  There are some tiled layers in the map, and they can look quite nasty when between LODs.  Is there a real fix?
lance
LanceCrumbliss
OK, i got around it by turning SnapToLevels to false before enabling the draw object.  for the record, this sill seems like a bug.
  End If
   End If
        Dim bSavedSnapValue As Boolean = Map.SnapToLevels
        Map.SnapToLevels = False
            Case "Pan"
                DrawActive = False
                _toolmode = "pan"
            Case "ZoomInTool"
                DrawActive = True
            Case "ZoomOutTool"
                DrawActive = True
        End Select
        Map.SnapToLevels = bSavedSnapValue
 End Sub
egismazeika
Is it your case?
Dominique, it IS the same case and we need a real fix.
DominiqueBroux
The fix should be in 2.0 final (to confirm by Morten).
