Move / Resize / Turn inserted graphic on a GraphicLayer
832
01-21-2013 03:33 AM
VictorRodriguez
Hi everyone,
I'm inserting images in a GraphicLayer in a map. My goal is moving, resizing and turning the already inserted images if a checkbox is checked and an image is clicked.
Can anybody help me, please?
private void ImageslayerMouseLeftButtonUp(object sender, GraphicMouseButtonEventArgs e)
    try
          var layer = Map.Layers[LayerIdentifiers.ImagesGraphicsLayer] as GraphicsLayer;
          if ((e.Graphic == null) || (layer == null))
                return;
          if (_resizeImage)
                // Here I need to show the Edit Vertices / Move Box on the clicked image. (e.Graphic)
      catch (Exception ex)
            UnhandledExceptionHandler.ShowFriendlyMessage(ex);
Thanks in advance and forgive my poor English.
DominiqueBroux
Esri Frequent Contributor
Did you look at this sample?
http://www.arcgis.com/home/item.html...b64a2d421d5716
Live version: http://serverapps.esri.com/Silverlig.../GeoReference/
It allows you to calculate the parameters needed to correctly place an image, including rotation.
I am not sure it's exactly what you need, but it could give you ideas on how to develop what you are looking for.
