Move multiple graphics at once
1067
09-22-2010 12:41 PM
FrancoisChartrand
Is it possible to move multiple graphics at once (using the Editor class or anything else)?
Thank you
JenniferNery
There is no support for moving multiple graphics at once.
dotMorten_esri
Esri Notable Contributor
With a little coding you could do that.
First listen for mouse down and set e.Handled = true to prevent the map from panning when you drag.
Then on mousemove, go through all the features you want to move and offset the points/vertices the amount the mouse moved since the last event multiplied by the map.Resolution.
