Modifying symbol properties at runtime
1073
08-01-2010 08:02 PM
linusang
Hi, I would like the user to be able to change color and width of the LineSymbol class
i tried this in my resource dictionary...
<esri:LineSymbol x:Key="DefaultLineSymbol">
        <esri:LineSymbol.ControlTemplate>
            <ControlTemplate>
                <Path x:Name="Element" Stroke="{TemplateBinding Color}" StrokeThickness="{TemplateBinding Width}" />
            </ControlTemplate>
        </esri:LineSymbol.ControlTemplate>
    </esri:LineSymbol>
but there is a compile error saying ColorProperty is not in Control type
Any suggestions?
DominiqueBroux
Esri Frequent Contributor
Try binding to the symbol:
            <ControlTemplate>
                <Path x:Name="Element" Stroke="{Binding Symbol.Color}" StrokeThickness="{Binding Symbol.Width}" />
            </ControlTemplate>
    </esri:LineSymbol>
MartenLiebster
Not sure if it's the preferred way or not, but I did this in my symbol and it works fine:
(I realize the context is a bit different, in that I did inside of a MarkerSymbol instead)
<Ellipse
  Fill="{Binding Attributes,
         Converter={StaticResource DictionaryConverter},
         ConverterParameter=EllipseFill,
         Mode=OneWay}"
                                     Height="10"
                                     HorizontalAlignment="Left"
                                     Margin="-5,-5,0,0"
                                     VerticalAlignment="Top"
                                     Width="10" />
The EllipseFill value comes from the graphic's attribute collection.
*** EDIT ****
Looking over the blogs and changes for 2.0, looks like the converter is no longer needed.
An updated way might be like this:
<Ellipse
  Fill="{Binding Attributes[EllipseFill], Mode=OneWay}"
                                     Height="10"
                                     Margin="-5,-5,0,0"
                                     Width="10" />
linusang
Thanks this works great...
