Minor problem with Legend control
1632
12-02-2010 03:07 PM
ChrisNorth
I downloaded v2.1 this afternoon, and just added the Legend control into my application.
At runtime, the legend control works great. But, when I try to view the Design of my XAML page, VS throws an "InvalidCastException". Details are...
Unable to cast object of type 'Microsoft.Expression.DesignModel.DocumentModel.DocumentPrimitiveNode' to type 'Microsoft.Expression.DesignModel.DocumentModel.DocumentCompositeNode'.
at Microsoft.Expression.DesignModel.InstanceBuilders.ArrayInstanceBuilder.InstantiateTargetType(IInstanceBuilderContext context, ViewNode viewNode)
at Microsoft.Expression.DesignModel.InstanceBuilders.ClrObjectInstanceBuilder.Instantiate(IInstanceBuilderContext context, ViewNode viewNode)
at Microsoft.Expression.DesignModel.Core.ViewNodeManager.Instantiate(ViewNode viewNode)
Like I said, the legend works fine at runtime. In the XAML editor, my XAML code is:
<Border Background="#77919191" BorderThickness="1" CornerRadius="5"
HorizontalAlignment="Right" VerticalAlignment="Top"
Margin="20" Padding="5" BorderBrush="Black" >
<esri:Legend Map="{Binding ElementName=MyMap}"
LayerIDs="Businesses, Community Facilities, Education, Base Map Layer"
LayerItemsMode="Flat"
</Border>
Curiously, the XAML editor underlines the "LayerIDs=.." tag, and the tooltip shows the same cast error.
Am I missing something?
Chris
PS - The control (at runtime) is fantastic by the way - nice job.
DominiqueBroux
Esri Frequent Contributor
This is a VS2010 bug and unfortunately, we didn't find any workaround.
It only happens in design view of VS2010.
This is the same bug that VisibleLayers one : http://forums.arcgis.com/threads/18545-VisibleLayers-error
ChrisNorth
OK.  Thanks for the prompt reply.
OlegLukyanov
Did you find any workaround for Legend control now? Is it possible to use it in 2.2 API?
Thanks
DominiqueBroux
We didn't find any workaround yet.
Despite this error in the design view, your code will compile and run correctly.
KevinMayo
Grrrrr.... this line is breaking my intellisense in VS.
