Measure Radius Tool in Arcgis silverlight
4047
10-20-2010 02:20 AM
rohandontireddy
how to measure radius,area and circumference of a circle in meters where map coordinates are not decimal degrees
JenniferNery
You can use MeasureAction. It measures distance, area and radius on the map. It has several properties if you look at http://help.arcgis.com/en/webapi/silverlight/apiref/ESRI.ArcGIS.Client.Behaviors~ESRI.ArcGIS.Client..... MapUnits can be set to unit other than decimal degrees, MeasureMode can be Radius.  You can look at this sample: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#UtilityActions
