MarkerSymbol Bindings to it's Graphic
1353
03-08-2012 03:50 AM
jonataspovoas
I'm build a coordinate search to my appication. To do so, I'm using the following MarkerSymbol, to show the coordinates and a image that represents the point.
<ResourceDictionary
    xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
    xmlns:esri="http://schemas.esri.com/arcgis/client/2009">
    <esri:MarkerSymbol x:Key="MarcadorCustomizadoFerramentaCoordenadas" OffsetX="8" OffsetY="31">
        <esri:MarkerSymbol.ControlTemplate>
            <ControlTemplate>
                <StackPanel Orientation="Horizontal">
                    <Image Source="/ViewModel;component/RecursosGraficos/Imagens/marcadorCoordenadas.png"/>
                    <Border BorderBrush="Green" Background="White" BorderThickness="1">
                        <TextBlock Text="{Binding [Coordenadas]}" TextAlignment="Left" VerticalAlignment="Center"
                                   FontFamily="Portable User Interface"/>
                    </Border>
                </StackPanel>
            </ControlTemplate>
        </esri:MarkerSymbol.ControlTemplate>
    </esri:MarkerSymbol>
</ResourceDictionary>
The problem in this code is that the Binding get no value. This Binding was originaly on a MapTip code on the GraphicsLayer, and there it works fine.
Does Anyone knows how to make it work as a Graphic Symbol?
This is how I set the Marker as Symbol of the Graphic:
private void AdicionaPontoNoGraficsLayer(MapPoint ponto)
    mapaEmExecucao.PanTo(ponto);
    Graphic bandeiraBuscaPorCoordenadas = new Graphic();
    bandeiraBuscaPorCoordenadas.Attributes.Add("Coordenadas",
                                                string.Format("X: {0}\nY: {1}",
                                                             Math.Round(ponto.X, 4),
                                                             Math.Round(ponto.Y, 4)));
    bandeiraBuscaPorCoordenadas.Geometry = ponto;
    bandeiraBuscaPorCoordenadas.Symbol = RecursosGraficos.RecursosGraficos.ObtemImagem(RecursosGraficos.RecursosGraficos.Imagens.MarcadorCustomizadoFerramentaCoordenadas);
    GraphicsLayer resultadoBuscaCoordenada = mapaEmExecucao.Layers["ExibePontosFerramentaCoordenadas"] as GraphicsLayer;
    resultadoBuscaCoordenada.Graphics.Add(bandeiraBuscaPorCoordenadas);
jonataspovoas
Hi again,
I'm still trying to make it work, but now I'm trying a different approach:
I made now two graphics: one with the image, another with the text.
The image symbol is working well, but I now have the same problem I had on the text Field.
Here is the template I tried to build:
<ResourceDictionary
    <esri:TextSymbol x:Key="MarcadorTextualDaFerramentaCoordenadas">
        <esri:TextSymbol.ControlTemplate>
            <ControlTemplate>
                <TextBlock Text="What Goes here?"
                           FontWeight="Bold"
                           FontSize="10"
                           Foreground="Red"/>
            </ControlTemplate>
        </esri:TextSymbol.ControlTemplate>
    </esri:TextSymbol>
The problem in it is that I don't know what to bind the textblock to...
DaveOrlando
I had the same situation.
the binding is different for MapTips vs the custom symbol (control template). try adding 'Attributes' to the binding statement
Text="{Binding Attributes[AREANAME]}"
(any idea how to switch to a different attribute from codebehind based on a user selection?)
hope that helped
