MapTip is not working.
4857
14
03-17-2011 12:17 AM
ManojrajTeli
I have many layers in my project and one of the layer is "valve".Now i have created the maptip in my mxd also for individual valve layer and it works in mxd but in my silverlight application it doesn't work. I have tried the examples from Interactive SDE but it is not displaying anything even i tried to catch exception and tried showing in text-block but even text-block is also black.Thank in advance and please help.
DominiqueBroux
Esri Frequent Contributor
We would need more infos on what you did in order to help you.
Reminder just in case:
  • maptips are only working with GraphicsLayer and FeatureLayer (not working with ArcGISDynamicMapService layers)
  • the maptips you created in the mxd with arcmap are not used by the client API. You have to redefine them at the client side
ManojrajTeli
My valve layer is ArcGISDynamicMapServiceLayer.Is there any way to convert ArcGISDynamicMapServiceLayer into feature or graphics layer because i have created service of valve layer seperatelly and i am using it.Is there any work around please suggest .Thank you in advance.
DominiqueBroux
You can create your valves as graphics by adding a feature layer to your map.
Something like:
<esri:Map>
     <esri:FeatureLayer Url="<MyMapServiceURL>/<ValveLayerSubID>" />
JenniferNery
This also seems related to this thread: http://forums.arcgis.com/threads/25018-MapTips-widget-Vs-Graphic-MapTips-Vs-InfoWindow-(which-one-to... Kindly see post#2 for some other options when using dynamic layer.
ManojrajTeli
I tried maptip and InfoWindow but not single thing is working it doesnot show any error also.Please help me out i need it urgently.thank you in advance.
ManojrajTeli
I took demo of maptip and i have put my local sevices and still its not working is it that my sevices are having some problem i am using arcgis 10.Please help me with this issue..Thank you in advance.
Error message"ESRI.ArcGis.Client.Task.service Exception object reference not set to an instance of an object."
ManojrajTeli
I have even tried this demo
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#Identify
but it still failed can anyone help me out.
DominiqueBroux
http://help.arcgis.com/en/webapi/sil...t.htm#Identify
Very difficult to guess what could be your issue:confused:.
What are you doing exactly? How does it fail?
ManojrajTeli
Asset maping for water supply department and i have many created many dynamic layers for valve,pipeline etc now i want whenever user mouse point at valve then it should show information in panel. Thats all i want please help me if possible.
