Map Tip line graphics?
956
03-15-2011 10:40 AM
ShawnaErnst
Hello!
We're trying to create a map tip for line graphics, but it seems that the cursor isn't "sensitive" enough to actually find the line.
So, we're now trying to query our map service to get a line graphic, then buffering that line graphic to get a polygon and then passing the polygon buffer back to the map service to query for a line...and then finally map-tipping the line.  That solution works (sort of) - we get a map-tip, but we have problems where our buffers overlap.
Is there a better way to create map tips for lines?
Shawna
JenniferNery
Which MapTip are you using?
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#MapTipWidget, or
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#GraphicsMapTip
Can you share your line symbol? MapTip in both cases open when graphic element is entered. I wonder if your symbol template include IsHitTestVisible="False" somewhere.
dotMorten_esri
Esri Notable Contributor
Could you make your lines wider?
