Map Scale - New Feature
1496
12-15-2011 07:18 AM
GISProgrammer
I was checking out the Map Scale
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#MapScale
and I had a easy, silly question.  Is it reporting the Display Units based on the map spatial ref?  In the example the Spatial Reference: 102100 (3857) - Units: esriMeters?  If yes is there a way to hard code the display units.  Something similar to the scale bar (MapUnit="Meters" DisplayUnit="Miles").  I couldn't locate the any library ref.
Thanks
DominiqueBroux
Esri Frequent Contributor
A scale is a ratio and thus has no unit.
As a consequence, we don't need any DisplayUnits for reporting a scale (but for sure, the calculation of the scale is taking care of the spatial reference units).
GISProgrammer
Dom,
If I understand you correctly the example in the SDK is a spatial Reference: 102100 (3857) - Units: esriMeters so the scale is 'one centimetre to whatever number is displayed esriMeters'   ????
I guess I'm thinking of scale as 1inch equals a Mile  or  'one centimetre to one thousand kilometres'
Is this right?  What is the expression in words for the example (as a ratio - it is showing a number so One ???? equals the displayed EsriMeters.
Is it possible to change the ratio units like 'one inch to one mile'    or    1:63,360    or    1/63,360
Thanks
DominiqueBroux
No. Looks like I was unclear.
You don't need to know that the SR is in meters.
A scale is the ratio of a distance on the map to the corresponding distance on the ground. It's not depending on the units.
A scale of 1:1000 means that 1 unit on the map equals 1000 units on the ground.
That's working whatever the units : 1 inch on the map = 1000 inches on the ground,
1cm on the map = 1000 cm on the ground, 1foot on the map equal 1000feet on the ground, ........
MuhammadWaqar_ul_islam
well i m trying to used Map scale my version of ARCGIS API 2.2 does it required 2.3
DominiqueBroux
You are right, map scale support has been introduced in 2.3.
