Map Printing Issue with my map services
4718
7
10-18-2011 03:35 AM
MuhammadWaqar_ul_islam
i have used sample for map printing mention by dbroux
http://www.arcgis.com/home/item.html?id=e361c2cc69784fcba34358d0458f66e3
it works fine
but i have little problem with scale and pages in MapPrint dialog using my services
its shows a single page to print and when i click on print button its doesnot show scale its Shows NAN Kilometer
while using this service http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer
pages and scale works fine
i m attaching both files for reference
by Anonymous User
Not applicable
Original User: dbroux
It's likely because the program can't find out the map units by itself.
Setting manually the 'MapUnits' property of the MapPrinter should help.
Sidenote : from 2.3 the API will provide a way to get the scale without setting manually the map units.
thanks dbroux
it is working but still i problem remains
print to scale  doesnt change the extent
1:3400000 scale print is same as 1:1200 ( create confusion)
i attaching images for urs reference to understand
and when version 2.3 is available for us
by Anonymous User
Not applicable
thanks dbroux
It's not just confusion, it's not working at all:confused:.
What are your map units?
In the preview window, do you see the page numbers changing when modifying the scale?
If your service is public, can you share the Url in order me to test.
Thanks for reply
My service is not public so can't share the url
In the preview window, it shows only a single page 1
when modifying the scale no changes occurs in page numbers
My units are in meter
UTM WGS1984 is projection
Origin:
X: -5120900
Y: 9998100
Spatial Reference: 32642
Intial Extent:
XMin: 275353.299157335
YMin: 2731407.98325904
XMax: 345891.356900117
YMax: 2782809.53322303
Full Extent:
XMin: 276887.885559841
YMin: 2735545.1734472
XMax: 344356.770497611
YMax: 2778672.34303487
Units: esriMeters
what next to do
by Anonymous User
Not applicable
I did some tests.
I get this kind of wrong result if the MapUnits are not initialized and can't be found automatically.
But it looks working well if the MapUnits are manually initialized.
Did you set the MapPrinter MapUnits?
Something like :
controls:MapPrinter x:Name="mapPrinter" Map="{Binding ElementName=MyMap}" MapUnits="Meters" ......
thanks dbroux
its working using mapunits = "meter"
for forget to add mapunits in mapprint control
its also helps others if add this line in read me file (thanks alot) u r always helping us
One more thing i want to ask in esri  book mark
when we add some bookmark wants to clear a single book marks its clear all bookmark
is there any possibility to clear a selected bookmark only no all
by Anonymous User
Not applicable
Glad you got it working 🙂
Concerning the possibility to clear the selected bookmarks, there is a sample here.
