Map layers that don't draw
857
05-08-2013 10:39 AM
DonFreeman
Can someone suggest why my map (see below) will only draw the TAZ layer and will not draw the other 2 (at any scale)? The other 2 do have scale ranges set but required zoom is not high. It works fine when viewed in ArcGIS online. If I remove the scale ranges, they still do not draw. Is there something wrong with the service or server?
Thanks.
<Grid Name="MapGrid" Grid.Column="1" Margin="5,5,15,5">
    <Rectangle Fill="LightGray"
      RadiusX="10"
      RadiusY="10"
      Margin="0,10,10,0"
      Height="Auto"
      Stroke="SaddleBrown"
      StrokeThickness="4"/>
    <esri:Map x:Name="MyMap"  Extent="748437,575771,1204687,267438" Margin="10,20,20,20" IsLogoVisible="False" >
     <esri:Map.Layers>
      <!--<esri:ArcGISDynamicMapServiceLayer ID="PAGBaseMap"
       Url="http://gismaps.pagnet.org/ArcGIS/rest/services/PAGBaseMap/MapServer" VisibleLayers="1,2,3" />-->
      <esri:FeatureLayer ID="ParcelLayer"
             Url="http://gismaps.pagnet.org/ArcGIS/rest/services/TAZ/MapServer/1"
             Visible="True"
             OutFields="*" />
      <esri:FeatureLayer ID="CensusBlockLayer"
             Url="http://gismaps.pagnet.org/ArcGIS/rest/services/TAZ/MapServer/0"
             Visible="True"
             OutFields="*" />
      <esri:FeatureLayer ID="TAZLayer"
             Url="http://gismaps.pagnet.org/ArcGIS/rest/services/TAZ/MapServer/2"
             Visible="True"
             OutFields="*" />
     </esri:Map.Layers>
    </esri:Map>
   </Grid>
