map extent based on window size
2661
9
11-18-2010 05:33 AM
ThaoNguyen
Has anyone set map extent based on window size?  Please share.
Thank you!!
AliMirzabeigi
You can use Maintain Extent Bahavior if you want to keep your current map extent:
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#MaintainExtentBehavior
ThaoNguyen
Thank you!  I tried the sample code, but got the following errors.  I guess the sample code is outdated?
Error 1 The tag 'Interaction.Behaviors' does not exist in XML namespace 'http://schemas.microsoft.com/expression/2010/interactivity'.
Error 3 The type 'arcgis:MaintainExtentBehavior' was not found. Verify that you are not missing an assembly reference and that all referenced assemblies have been built.
My code has the namespaces added in the UserControl header as follow:
xmlns:i="http://schemas.microsoft.com/expression/2010/interactivity"
xmlns:arcgis="http://schemas.esri.com/arcgis/client/2009"
Usage:
<i:Interaction.Behaviors>
        <arcgis:MaintainExtentBehavior x:Uid="meb" />
</i:Interaction.Behaviors>
AliMirzabeigi
You are missing the following references in your Silverlight application:
System.Windows.Interactivity
ESRI.ArcGIS.Client.Behaviors
ThaoNguyen
Usage:
Found 'solution' for error 1 at:
http://stackoverflow.com/questions/3059821/problem-using-blend-3-interaction-behaviours-in-vs2010
But after installing Blend SDK 4, didn't resolve the problem.
AliMirzabeigi
Did you also add the references I mentioned in my previous post (#4)?
ThaoNguyen
Just read your reply after I posted mine.  Yeah, that resolved the problem.  The sample code doesn't have those, but it references the url.  I removed the url lines and added the assembly references instead.  Thanks!!!
ThaoNguyen
ahhhh, still cannot try the sample solution.  I got assembly Interactivity below even though it's there in my references of the project.  I'm not sure what dependencies are missing either.
"Could not load file or assembly 'System.Windows.Interactivity, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The system cannot find the file specified."
JenniferNery
In your project references, does it show a warning symbol (!) next to the System.Windows.Interactivity? Can you check that when this assembly is selected the proper file path is located? Go to the path and see if the file exists (Kindly see attached).
Installing Blend 4, should have updated your registry so that these assemblies are found when you add reference to .NET assembly.
ThaoNguyen
There is no exclamation mark beside the dll reference and I also checked the path.  Everything is correct.  I also installed Blend 4 SDK.  Thanks for trying to help me!
