Map Cursors
5704
8
07-13-2010 07:37 PM
HaroldBostic
Has anyone changed the map cursor for the map to a custom cursor?  If so, how?
Thanks
dotMorten_esri
Esri Notable Contributor
There is no "custom" cursors in Silverlight, other than the few predefined ones. Instead set the Map.Cursor=Cursors.None, and use the MouseMove event to move a usercontrol that represents the cursor around, so it looks like its a cursor that follows the map. Make sure you also set IsHitTestVisible on the cursor, so it doesn't block mouse interaction with the map.
LawrenceSullivan
I don't get how to move the usercontrol on the map.
The map is not a convas, so I can not set LeftProperty and TopProperty. Am I missing something obvious?
Grond
LakshmananVenkatesan
Grond
Any clues or help?
DominiqueBroux
Esri Frequent Contributor
There is a nice sample of custom cursor here : http://www.arcgis.com/home/item.html?id=b77d416635a74e66ab222fe519af2eb7
Sample is good. How do I attach events to cursors. I have zoom in button, when user draws rectangle on Map and map will zoom accordingly. These cursors are images does not have any events.
DominiqueBroux
The sample has zoomin and zoomout buttons, so you can look on how it's developed.
You don't need any events on cursor, you can use the map events as with standard cursors.
Hi
Zoom in/out buttons were fixed extent zoomin/out. I want to zoom in based on user drawn rectangle over the map, for this how do I go about?. I need to draw a rectangle with zoom in cursor?. Hope my question is clear.
SR
DominiqueBroux
Looks like we are not talking about the same sample.
I attached a screenshot of the zoomin command in action
