Map can't be dragged in the ListBox
1288
05-26-2010 11:40 PM
hunterruan
I have a listbox to show the items with maps, but I can't drag the map by the mouse.
What can I do if I want to control the map by mouse.
For example:
<Grid x:Name="LayoutRoot">
        <ListBox Width="600" Height="400"  Margin="0,5,0,10">
            <esri:Map x:Name="LocalMap" Width="600" Height="400" >
                <esri:ArcGISTiledMapServiceLayer ID="MyLayer"
                Url="http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer" />
            </esri:Map>
        </ListBox>
    </Grid>
dotMorten_esri
Esri Notable Contributor
The listbox is cancelling the mouse events, preventing the map from receiving these events. Unfortunately there's not much the map can do to prevent this.
hunterruan
Ok. Thanks for your reply.
DominiqueBroux
Esri Frequent Contributor
It looks like by using the ScrollableMap sample, I posted a few days ago (http://resources.esri.com/arcgisserver/apis/silverlight/index.cfm?fa=codeGalleryDetails&scriptID=169...), it should work inside a listbox (even without using the scrollviewer capabilities).
Without scrollviewer for the item:
<ListBox Margin="0,5,0,10">
    <local:ScrollableMap>
        </esri:Map>
</ListBox>
With a scrollviewer for panning the map:
   <ScrollViewer ScrollViewer.HorizontalScrollBarVisibility="Auto" ScrollViewer.VerticalScrollBarVisibility="Auto">
        </esri:Map>
 </ScrollViewer>
</ListBox>
hunterruan
        </esri:Map>
</ListBox>
        </esri:Map>
 </ScrollViewer>
</ListBox>
I have test it successfully. Thank you very much.
