Map and ScrollBar
1674
6
01-16-2012 02:45 AM
jonataspovoas
In my project, I have a map that needs to be inside a ScrollBar. My problem is that when I do so, I lose the Pan functionality of the map. I really must find some way to make the pan work, and i also must give the user the possibility to scrolling possibility on the window (a ChildWindow) so it can see the whole content of the page.
DominiqueBroux
Esri Frequent Contributor
Look at this sample. There is a hack at the end of ScrollableMap.cs (without any guarantee though)
jonataspovoas
The sample didn't open...
DominiqueBroux
What do you mean? I just tested and I am able to view the live application and I am able to download the code and get the ScrollableMap.cs file.
jonataspovoas
I managed to get the code (the proxy on my workplace was blocking the page), but I couldn't use the "hack" to assign the mouseLeftButtonDown/Up to the map. The path to my map is something like this:
I have my ScrollViwer, and inside of it a Grid. The Grid gets through code the UserControl I use to define the ScrollViwer's content. It has another Grid that holds a StackPanel, that has Border countaining a Grid that has the Map, and a Navigator.
<ScrollViewer Margin="0,8,8,8"
              BorderBrush="{x:Null}"
              HorizontalScrollBarVisibility="Auto"
              VerticalScrollBarVisibility="Auto">
    <Grid x:Name="GridThatHoldsTheContent"/>
</ScrollViewer>
<StackPanel Grid.Row="0"
            MaxHeight="1454"
            VerticalAlignment="Top"
            Margin="25,25,28,0">
    <Border BorderThickness="1"
            BorderBrush="Black">
        <Grid>
            <esri:Map x:Name="Mapa"
                      WrapAround="True"
                      Background="#FFC3D2E5"
                      IsLogoVisible="False"
                      Height="1187">
                <i:Interaction.Triggers>
                    <i:EventTrigger EventName="ExtentChanged">
                        <i:InvokeCommandAction Command="{Binding AcaoExtentChanged}"
                                               CommandParameter="{Binding ElementName=Mapa}"/>
                        <ei:CallMethodAction MethodName="InvocaOMetodoDeHistoricosDoMapaNaViewModel"
                                             TargetObject="{Binding ElementName=PaginaRetratoA3}"/>
                        <ei:CallMethodAction MethodName="ConfiguraExibicaoDeLegenda"
                    </i:EventTrigger>
                </i:Interaction.Triggers>
            </esri:Map>
            <esri:Navigation VerticalAlignment="Bottom"
                             Margin="10,0,0,10" Background="#FF336397"
                             Style="{StaticResource EstiloNavegadorImpressao}"
                             Map="{Binding ElementName=Mapa}"/>
        </Grid>
    </Border>
</StackPanel>
What should I do?
DominiqueBroux
I got it working with this code:
public partial class TestScrollViewer : UserControl
    public TestScrollViewer()
        InitializeComponent();
        MyMap.Loaded += AttachMouseLeftButtonHandlers; // maybe set in XAML as well : Loaded="AttachMouseLeftButtonHandlers"
    private void AttachMouseLeftButtonHandlers(object sender, RoutedEventArgs e)
        Map map = sender as Map;
        // Get the "RootElement" of the map   ~ of map.GetTemplateChild("RootElement") but GetTemplateChild is protected and Map is sealed
        var rootElement = ((FrameworkElement)VisualTreeHelper.GetChild(map, 0)).FindName("RootElement") as Grid;
        if (rootElement != null)
            rootElement.MouseLeftButtonDown += RootElement_MouseLeftButtonDown;
            rootElement.MouseLeftButtonUp += (s, arg) => _upFired = true;
    // Hack to get the map taking care of the MouseLeftButtonDown event even if
    // this event is handled by the a parent element such as a scrollviewer
    private bool _upFired;
    void RootElement_MouseLeftButtonDown(object sender, MouseButtonEventArgs e)
        _upFired = false;
        Dispatcher.BeginInvoke(() =>
                                    if (!_upFired) // else up event fired meanwhile
                                        e.Handled = false;
Reminder : code provided without any guarantee of good behavior for future versions or even for this version.
jonataspovoas
It worked!
Thanks a lot for your help!
