Make Route Event Layer Shape not found
2822
01-27-2012 02:35 AM
SantoshV
HI ..
  I have a issue with creating a layer using Make Route event Layer using an event table
When I create a event layer some of the geometry is not created it shows no shape/shape length = 0
but it has an attribute table
Because of this I am not able to show this graphic on the map  please do guide in fixing this problem...[ATTACH=CONFIG]11465[/ATTACH]
SimonPerron
Normally this situation happens when the ''event's route id'' is not found in the Route layer. Instead of dropping the unreferenced events, it keeps it but with a geometry equal to 'null'. You could first verify for one of these events that failed, what is the RouteID written. Then look in your Route Layer if you can really find this route ID.
SantoshV
Yup you were right
thnx 🙂
