Make cluster point bigger when zoomed out
3131
12-10-2013 11:14 AM
JohnPreston
Hi I have added a flare cluster to my map and it works great. However, when zoomed out and the the number of points within the radius is greater than the max the dot on map with the number in it is very small. For example when I zoomed out I have 7 points in an area. The dot appears with the #7 in the middle but it is very small...
[ATTACH=CONFIG]29734[/ATTACH]
Can I make the dot bigger?
GirishYadav
You can create your own Custom Cluster symbol with whatever look (size, color, style) you want. Please checkout these samples by ESRI
SimpleClustererCustomClusterer
It gives a very good idea to create custom cluster symbol. Find more detailed information in ArcGIS Silverlight API reference
look for overview of FlareClusterer class inside ESRI.ArcGIS.Client.
Girish
JohnPreston
Thanks Girish, I can make the actual flare cluster look the way I want but I am having problems chaning the appearance when it is zoomed out and is more than the max. The dot gets bigger when you have more items. I want to change that dot.
[ATTACH=CONFIG]29987[/ATTACH]
in the above picture, those dots change size based on number on items in the radius but they are not flare clusters.
Can I change those big dots?
Thanks!
