Make a grid draggable
1057
05-01-2012 01:50 PM
YassineEL_JADIDI
Hello,
i want to make a grid draggable all over my map.
it is possible, any idea ?
Thanks
JMcNeil
You should check out the template gallary - http://help.arcgis.com/en/webapi/silverlight/samples/TemplateGalleryWeb/start.htm
Specifically look at the Showcase gallery  - http://help.arcgis.com/en/webapi/silverlight/samples/TemplateGalleryWeb/Samples/Customized_Templates...
The showcase map and code has a DraggableWindow Class, which will allow you to wrap your grid inside the DraggableWindow and then be able to move it around.
Jay
