Magnifier tool and Dynamic layers
3081
12-20-2010 12:11 AM
MatthewPilgrim
EDIT: This works when pointing at all layers but not one layer i.e. Mapserver/0
I'm sure I read somewhere that the ESRI Magnifier tool works with multiple layers and dynamic layers. However I can't seem to get dynamic layers to display. Here is a very simple example based on the sample server.
XAML:
<UserControl x:Class="MapApp.MainPage"
    xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
    xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
    xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
    xmlns:esri="http://schemas.esri.com/arcgis/client/2009"
    xmlns:esriSymbols="clr-namespace:ESRI.ArcGIS.Client.Symbols;assembly=ESRI.ArcGIS.Client"
    mc:Ignorable="d"
    d:DesignHeight="300" d:DesignWidth="400">
    <Grid x:Name="LayoutRoot" Background="White">
        <esri:Map x:Name="MyMap" MouseLeftButtonDown="MyMap_MouseLeftButtonDown">
            <esri:Map.Layers>
                <esri:ArcGISDynamicMapServiceLayer ID="StreetMapLayer" Url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer" />
            </esri:Map.Layers>
        </esri:Map>
        <Canvas>
            <esri:Magnifier x:Name="MyMagnifier" ZoomFactor="2" Map="{Binding ElementName=MyMap}" Canvas.ZIndex="10">
                <esri:Magnifier.Layers>
                    <esri:ArcGISDynamicMapServiceLayer ID="MagnifyImageLayer"
                        Url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/0" />
                </esri:Magnifier.Layers>
            </esri:Magnifier>
        </Canvas>
    </Grid>
</UserControl>
Code behind:
using System;
using System.Net;
using System.Windows.Controls;
using System.Windows.Input;
namespace MapApp
    public partial class MainPage : UserControl
        public MainPage()
            InitializeComponent();
        private void MyMap_MouseLeftButtonDown(object sender, MouseButtonEventArgs e)
            MyMagnifier.Enabled = !MyMagnifier.Enabled;
And the error message:
Line: 56
Error: Unhandled Error in Silverlight Application
Code: 4004
Category: ManagedRuntimeError
Message: System.ArgumentException: Service URL does not contain any layer.
at ESRI.ArcGIS.Client.Layer.OnInitializationFailed(EventArgs e)
at ESRI.ArcGIS.Client.Layer.Initialize()
at ESRI.ArcGIS.Client.ArcGISDynamicMapServiceLayer.<>n__FabricatedMethod8()
at ESRI.ArcGIS.Client.ArcGISDynamicMapServiceLayer.<>c__DisplayClass6.<MapServiceInfoInitFailed>b__4()
Note I've tried pointing the magnifier at "MapServer" which works but "MapServer/0" doesn't.
Should pointing at one layer work?
Secondly, with our own map server I can load the dynamic layers with a zoom level of 1.5 but when this is increased to say 2.0 they stop appearing. Is there something server side that limits the zoom factor?
Thanks, Matt
DominiqueBroux
Esri Frequent Contributor
If you are pointing one layer, you have to use a FeatureLayer instead of an ArcGISDynamicMapServiceLayer.
Might be a minimum resolution set on the layer.
MatthewPilgrim
I've just tried:
                        Url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/1" />
And get the same error message.  Can you elaborate on what should/shouldn't work please?
I'll check the resolution issue.
Thanks again, Matt
DominiqueBroux
<esri:ArcGISDynamicMapServiceLayer ID="MagnifyImageLayer" Url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/0" />
http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/Map... is the URL of a FeatureLayer not a map service layer.
So, should work:
<esri:FeatureLayerID="MagnifyImageLayer" Url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/Map.../0" />
or
<esri:ArcGISDynamicMapServiceLayer ID="MagnifyImageLayer" Url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/Map..." VisibleLayers="0" />
MatthewPilgrim
My mistake!  Your second example gave me the clue I needed.
Matt
