load geotiff or other raster from a remote url
1324
5
07-05-2011 11:53 PM
devrim_barisacar
Hi
I am just evaluating silverlight for a project proposal.
Can I load a raster image without using arcgis server(I have seen samples load from KML)?  For example from an URL like http://myserver.com/worldBackground.tiff.
Thanks in advance.
DominiqueBroux
Esri Frequent Contributor
You can use an ElementLayer to display images or videos.
There is a sample here : http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#MediaLayer
Note that Silverlight doesn't support tiff format though.
So you will need either a 3rd party component or a conversion to a supported format (jpeg, png (no gif nor tiff)).
devrim_barisacar
Thank you Dominique.
I am not allowed to use the local ARCGIS Server for serving the world image.
So my solution was to load this world image layer from a file or url.
As far as I understand from the sample I will replace the
     Source="http://serverapps.esri.com/media/scec-shakeout-simulation-rt.wmv"
line with the url of the imagery and I will be done , correct?
If I change the projection of the map, will this imagery also change projection?
Best regards
baris
DominiqueBroux
Almost! You have also to set the esri:ElementLayer.Envelope to the correct map coordinates for your image.
Nothing automatic. You have to adapt the envelope of your element to the map coordinates.
devrim_barisacar
Doing this adaptation, are there any libraries I can make use of during calculation of this transformation between projections? Or am I on my own?
DominiqueBroux
The most general answer is the Geometry service (sample here :http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#Project).
For the particular case of transformations between webmercator and geographical coordinates, you can use the WebMercator class : http://help.arcgis.com/en/webapi/silverlight/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.Projection...
Nothing else is available at the client side (for the moment).
