Load an ESRI Shape File
4254
15
05-13-2011 10:48 AM
MichaelAquilina
Hey guys, i was wondering if the ArcGIS library for WPF contains a method or class for loading and saving Shape file information.
I am aware that the format for a shape file is documented, so i could implement it myself if needed; but if the method is readily available there would be no need for this.
IgressT
If you can... please send me a copy at
[email protected]
ErikEngstrom
Nevermind... I was able to get the api sample to work correctly.
I needed to repair the assemblies and download the Reactive package from Microsoft. I seemed to get it working this way. I then added the SLContrib project to my site and added the code from the Contrib website. Worked perfectly... I just need to tweak it a bit to account for the differences in projections between the shapefiles we manage and the web mercator projection our web applications use.
weiliang
Could you send your code to me, Michael? I'd like to see how you implement it. My email is [email protected] .
Many thanks,
Wei
MargoBlosser
Michael,
Rectifying assemblies- yuck! I sure would appreciate getting a copy of your code snippet for loading a shape file.
Best Regards,
Margo
[email protected]
MichaelAquilina
Wow, didnt realise there was such a demand for the code!
Here it is guys, enjoy!
public enum ShapeType
        NullShape,
        Point, PolyLine, Polygon, MultiPoint,
        PointZ, PolyLineZ, PolygonZ, MultiPointZ,
        PointM, PolyLineM, PolygonM, MultiPointM,
        MultiPatch,
        Unknown
    public class ShapeFile
        public static ShapeType[] SupportedShapes = new ShapeType[] { ShapeType.PolyLine, ShapeType.Point };
        public ShapeType ShapeType;
        public int FileLength;
        public int Version;
        public int FileCode;
        public BoundingBox Boundary;
        public List<VectorShape> Data = new List<VectorShape>();
        public void Read(String ShapeFile )
            FileStream Stream = new FileStream(ShapeFile, FileMode.Open);
            BinaryReader Reader = new BinaryReader(Stream);
            FileCode = (int) ReverseBytes((UInt32)Reader.ReadInt32());
            if (FileCode != 9994)
                throw new IOException("The Input file specified is not a valid Shape File (Invalid FileCode)");
            //read empty bytes found in the file
            Reader.ReadBytes(20);
            FileLength = (int) ReverseBytes((UInt32)Reader.ReadInt32());
            Version = Reader.ReadInt32();
            ShapeType =  GetShapeType(Reader.ReadInt32());
            if (ShapeType == ShapeType.Unknown)
                throw new IOException("The Input file has an unknown Shape Type Specified");
            if (!SupportedShapes.Contains(ShapeType))
                throw new IOException("The Input file has a shape type that is not suppored (" + ShapeType + ")\n" +
                                      "The Following types are supported:\n" +
                                      SupportedShapes);
            Boundary = new BoundingBox();
            Boundary.XMin = Reader.ReadDouble();
            Boundary.YMin = Reader.ReadDouble();
            Boundary.XMax = Reader.ReadDouble();
            Boundary.YMax = Reader.ReadDouble();
            Boundary.ZMin = Reader.ReadDouble();
            Boundary.ZMax = Reader.ReadDouble();
            Boundary.MMin = Reader.ReadDouble();
            Boundary.MMax = Reader.ReadDouble();
            while (Stream.Position < FileLength)
                int RecordNumber = (int)ReverseBytes((UInt32)Reader.ReadInt32());
                int ContentLength = (int)ReverseBytes((UInt32)Reader.ReadInt32());
                ShapeType RecordShapeType = GetShapeType( Reader.ReadInt32() );
                switch( RecordShapeType )
                    case ShapeType.Point: Data.Add(ReadPoint(Reader)); break;
                    case ShapeType.PolyLine: Data.Add(ReadPolyLine(Reader)); break;
            Stream.Close();
        public void Write(String ShapeFile)
            FileStream Stream = new FileStream(ShapeFile, FileMode.Create);
            BinaryWriter Writer = new BinaryWriter(Stream);
            Writer.Write( ReverseBytes(9994) );     //filecode
            Writer.Seek(28, 0);                     //file length
            Writer.Write( (int) 1000);              //Version
            Writer.Write(GetShapeCode(ShapeType));
            Writer.Write(Boundary.XMin);
            Writer.Write(Boundary.YMin);
            Writer.Write(Boundary.XMax);
            Writer.Write(Boundary.YMax);
            Writer.Write(Boundary.ZMin);
            Writer.Write(Boundary.ZMax);
            Writer.Write(Boundary.MMin);
            Writer.Write(Boundary.MMax);
            for (int i = 0; i < Data.Count; i++)
                Writer.Write((int)ReverseBytes((UInt32)i));
                Writer.Write((int)ReverseBytes((UInt32)Data.SizeOf()));       //content length
                if (Data is PolyLine)
                    Writer.Write(GetShapeCode(ShapeType.PolyLine));
                    WritePolyline(Writer, (PolyLine) Data );
                if (Data is Point )
                    Writer.Write(GetShapeCode(ShapeType.Point));
                    WritePoint(Writer, (Point) Data );
            int FileLength = (int) Stream.Position;
            Writer.Seek(24,0);
            Writer.Write((int)ReverseBytes((UInt32)FileLength));
            Stream.Close();
        private void WritePoint(BinaryWriter Writer, Point Point)
            Writer.Write(Point.X);
            Writer.Write(Point.Y);
        private Point ReadPoint(BinaryReader Reader)
            Point Point = new Point();
            Point.X = Reader.ReadDouble();
            Point.Y = Reader.ReadDouble();
            return Point;
        private void WritePolyline(BinaryWriter Writer, PolyLine PolyLine)
            Writer.Write(PolyLine.XMin);
            Writer.Write(PolyLine.YMin);
            Writer.Write(PolyLine.XMax);
            Writer.Write(PolyLine.YMax);
            Writer.Write(PolyLine.NumParts);
            Writer.Write(PolyLine.NumPoints);
            for (int i = 0; i < PolyLine.NumParts; i++ )
                Writer.Write( PolyLine.Parts );
            for (int i = 0; i < PolyLine.NumPoints; i++)
                WritePoint(Writer, PolyLine.Points);
        private PolyLine ReadPolyLine(BinaryReader Reader)
            PolyLine Output = new PolyLine();
            Output.XMin = Reader.ReadDouble();
            Output.YMin = Reader.ReadDouble();
            Output.XMax = Reader.ReadDouble();
            Output.YMax = Reader.ReadDouble();
            Output.NumParts = Reader.ReadInt32();
            Output.NumPoints = Reader.ReadInt32();
            Output.Parts = new int[Output.NumParts];
            Output.Points = new Point[Output.NumPoints];
            for (int i = 0; i < Output.Parts.Length; i++)
                Output.Parts = Reader.ReadInt32();
            for (int i = 0; i < Output.Points.Length; i++)
                Output.Points = ReadPoint(Reader);
            return Output;
        public static UInt32 ReverseBytes(UInt32 value)
            return (value & 0x000000FFU) << 24 | (value & 0x0000FF00U) << 8 |
                   (value & 0x00FF0000U) >> 8 | (value & 0xFF000000U) >> 24;
        public static int GetShapeCode(ShapeType Type)
            switch (Type)
                case ShapeType.NullShape : return 0;
                case ShapeType.Point: return 1;
                case ShapeType.PolyLine : return 3;
                case ShapeType.Polygon: return 5;
                case ShapeType.MultiPoint: return 8;
                case ShapeType.PointZ: return 11;
                case ShapeType.PolyLineZ: return 13;
                case ShapeType.PolygonZ: return 15;
                case ShapeType.MultiPointZ: return 18;
                case ShapeType.PointM: return 21;
                case ShapeType.PolyLineM : return 23;
                case ShapeType.PolygonM : return 25;
                case ShapeType.MultiPointM: return 28;
                case ShapeType.MultiPatch: return 31;
                default :return -1;
        public static ShapeType GetShapeType(int Code)
            switch (Code)
                case 0: return ShapeType.NullShape;
                case 1: return ShapeType.Point;
                case 3: return ShapeType.PolyLine;
                case 5: return ShapeType.Polygon;
                case 8: return ShapeType.MultiPoint;
                case 11: return ShapeType.PointZ;
                case 13: return ShapeType.PolyLineZ;
                case 15: return ShapeType.PolygonZ;
                case 18: return ShapeType.MultiPointZ;
                case 21: return ShapeType.PointM;
                case 23: return ShapeType.PolyLineM;
                case 25: return ShapeType.PolygonM;
                case 28: return ShapeType.MultiPointM;
                case 31: return ShapeType.MultiPatch;
                default: return ShapeType.Unknown;
AzharIbrahim
I took too much time trying to find the assembly so i decided to implement a method for reading and writing shape files myself.....was surprisingly easy! If anyone wishes some simple code snippets for help just ask 🙂
Thanks for the help!
Could you please send me some code snippets?
