ListBox SelectionChanged zoom to index??
1750
6
08-29-2012 11:31 PM
BrianHjort_Nielsen
im having a problem with Zooming to a populated ListBox, i have a query that populates the Listbox and Zooms to the first object in the ListBox, but when i try to click on another object in the Box, nothing happens.
I used to have my SelectionChanged event to route back to my "QueryTask_ExecuteComplete" and that worked, but the problem with this was, that it added objects to my ListBox every time i clicked on an object in it, and if i tried to do a whole new Query, it crashed if i had clicked on an object in the ListBox.
this is my "QueryTask_ExecuteComplete":
void QueryTask_ExecuteCompleted(object sender, ESRI.ArcGIS.Client.Tasks.QueryEventArgs args)
            //query.Text = comboBox1.SelectedItem.ToString();
            FeatureSet featureSet = args.FeatureSet;
            GraphicsLayer graphicsLayer = MyMap.Layers["MyGraphicsLayer"] as GraphicsLayer;
            graphicsLayer.ClearGraphics();
            foreach (Graphic graphic in args.FeatureSet.Features)
                comboBox1.Items.Add(graphic.Attributes["Name"].ToString());
            if (featureSet != null && featureSet.Features.Count > 0)
                Graphic selectedfeature = featureSet.Features[0];
                //QueryDetailsDataGrid.ItemsSource = featureSet.Features;
                //QueryListbox.ItemsSource = featureSet.Features;
                selectedfeature.Symbol = LayoutRoot.Resources["defaultFillSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol;
                graphicsLayer.Graphics.Add(selectedfeature);
                ESRI.ArcGIS.Client.Geometry.Envelope selectedFeatureExtent = selectedfeature.Geometry.Extent;
                double expandPercentage = 30;
                double widthExpand = selectedFeatureExtent.Width * (expandPercentage / 100);
                double heightExpand = selectedFeatureExtent.Height * (expandPercentage / 100);
                ESRI.ArcGIS.Client.Geometry.Envelope displayExtent = new ESRI.ArcGIS.Client.Geometry.Envelope(
                selectedFeatureExtent.XMin - (widthExpand / 1),
                selectedFeatureExtent.YMin - (heightExpand / 1),
                selectedFeatureExtent.XMax + (widthExpand / 1),
                selectedFeatureExtent.YMax + (heightExpand / 1));
                MyMap.ZoomTo(displayExtent);
THIS is my somewhat working SelectionChanged:
private void comboBox1_SelectionChanged(object sender, SelectionChangedEventArgs e)
            //if (comboBox1.SelectedItem.ToString().Contains("Name"))
                //return;
            QueryTask queryTask = new QueryTask("http://hkn082/ArcGIS/rest/services/Baskarta/Fastighetsytor/MapServer/2");
            queryTask.ExecuteCompleted += QueryTask_ExecuteCompleted;
            queryTask.Failed += QueryTask_Failed;
            ESRI.ArcGIS.Client.Tasks.Query query = new ESRI.ArcGIS.Client.Tasks.Query();
            query.ReturnGeometry = true;
            query.OutSpatialReference = MyMap.SpatialReference;
            //query.OutFields.Add("");
            queryTask.ExecuteAsync(query);
Any help would be helpful and appreciated
SanajyJadhav
If I understand correctly,you are populating ComboBox with the values which you got as a result of query.And, you want to zoom to selected item in the ListBox.If this is right, I have done something similar to this as below.
1. Created class that exposes two properties, first is name and other is geometry. Created private List<ThisClass> to hold instances of my class.
2. In the first query completed event, I had created instance of this class ,set its property name by "(graphic.Attributes["Name"].ToString());". And the geometry property by graphic.Geometry.Added this instance to the List.
3. Populated the ComboBox by this name property.
4. In the Combobox selection changed event, I would iterate thru this list, check name property and if name matches, I would use Geometry property of that instance to set the extent of the map.So ,no need to execute another query.
hope, this helps.
BrianHjort_Nielsen
hope, this helps.
Thanks for your reply!
Yes with one exception, im using a listbox instead, in my code i have changed the x:name of my listbox to that of an ComboBox i used to have in my build. ( i replaced the ComboBox with a ListBox).
do you have an example of the code, i tried something like what you say, but didnt get it to work...
SanajyJadhav
I'll put my code here tomorrow when I reach the office.
SanajyJadhav
.This is the class that saved the queried features.
 public class IdedFeatures
        public string LayerName { get; set; }
        public IDictionary<string, Object> AttrData { get; set; }
        public string DisplayString { get; set; }
        public Graphic idedGraphic { get; set; }
Below should be your query completed event.
 if (e.IdentifyResults != null && e.IdentifyResults.Count > 0)
                    //List that will hold the all identified features as an instance our custom class "IdedFeatures"
                    m_ListIdedFeatures = new List<IdedFeatures>();
    //loop thru each identified feature,create instance of the class "IdedFeatures", set its properties
                    //using IdentifiedFeature and add this instance to its list.
                    foreach (IdentifyResult idResult in e.IdentifyResults)
                        IdedFeatures idedFeat = new IdedFeatures();
                        idedFeat.LayerName = idResult.LayerName;
                        idedFeat.AttrData = idResult.Feature.Attributes;
                        idedFeat.idedGraphic = idResult.Feature;
                        idedFeat.DisplayString = idResult.LayerName + " : " + idResult.Value;
                        m_ListIdedFeatures.Add(idedFeat);
  //set datasource of combo box
cmbIdentifyResult.ItemsSource = null;
cmbIdentifyResult.ItemsSource = m_ListIdedFeatures;
Below is the selection changed event of my Combo. Your's would be for the ListBox.
//cast selected combo box item to the type of IdedFeatures so that we can have reference to the Graphic of the selected item.
    IdedFeatures selectedFeature = cmbIdentifyResult.SelectedItem as IdedFeatures;
//zoom to the extent of the extent of the selected item in the listbox
  MapControl.Extent = selectedFeature.idedGraphic.Geometry.Extent;
Let me know if this helps you.
Thanks.
BrianHjort_Nielsen
Hi again, and thanks!
I dont know if i am missing something or a reference, but i can't get the code to work, problems starts when i try to debug the code, what does your class header look like, my "querytask_executecompleted" is a "ESRI.ArcGIS.Client.Tasks.QueryEventArgs". and when i try out your code example i get the message that the arguments in your code cant be found in the class... =/
SanajyJadhav
Can you paste your code with point where code breaks here? Also, let me know the error message you are seeing.
