Linq Sort
2447
12
03-11-2011 12:15 PM
JayKappy
I have been trying to find an answer at Silverlight forums and LINQ forums but no luck....
I can sort by "officer" no problem....but I want to sort by the IncidentNumber field which is numberic...Cant seem to get it to sort...
I tried with no success:
  1. Order By CStr(g.Attributes("IncidentNum")) Ascending
  2. Order By CInt(g.Attributes("IncidentNum")) Ascending
  3. Order By CDbl(g.Attributes("IncidentNum")) Ascending
Works for Officer:
Dim results2 = From g In featureSet
        Order By CStr(g.Attributes("Officer")) Ascending
        Group g By GroupKey = CStr(g.Attributes("Officer")) Into r = Group
        Select New With {Key .Officer = GroupKey, Key .IncidentNums = r.Sum(Function(i) Convert.ToInt32(i.Attributes("IncidentNum")))}
Does NOT work for IncidentNumber (Map Service Field Name = IncidentNum)
JayKappy
The Field is an Integer.....
Tried using the actual Attribute field name "IncidentNum", NOTHING ..no sorting
                        Order By Convert.ToInt32(g.Attributes("IncidentNum")) Descending
                        Group g By GroupKey = DirectCast(g.Attributes("Officer"), String) Into r = Group
But then thinking...I am trying to sort the "Key .IncidentNums" being created by Sum, NOTHING ...no sortting...
                        Order By Convert.ToInt32(g.Attributes("IncidentNums")) Descending
Also...but getting errors
Order By Convert.ToInt32(g.Attributes("IncidentNum"), Integer) Descending
Order By Convert.ToInt32(g.Attributes("IncidentNum"), Double) Descending
Order By Convert.ToInt32(g.Attributes("IncidentNums"), Integer) Descending
Order By Convert.ToInt32(g.Attributes("IncidentNums"), Double) Descending
JenniferNery
Before you apply any sort, test that you can successfully perform the conversion.
Dim integerValue As Integer = Convert.ToInt32(g.Attributes("IncidentNum"))
If you can get the above code to work, I don't see why sorting against this value will not work.
JayKappy
first off once again I thank you with this issue....driving me nuts...I am trying my best which does nto seem to be enough....
problem is that alone g is undefined...I am defining g from the results of the query (featureset)
    Private Sub QueryTaskPolice_ExecuteCompletedListBox(ByVal sender As Object, ByVal args As ESRI.ArcGIS.Client.Tasks.QueryEventArgs)
        Dim featureSet As FeatureSet = args.FeatureSet
If I do this, I get the error that g is undefined...
I then tried..
        Dim integerValue As Integer = Convert.ToInt32(featureSet.Attributes("IncidentNum"))
.Error 1 'Attributes' is not a member of 'ESRI.ArcGIS.Client.Tasks.FeatureSet'.
Then tried this
        Dim integerValue As Integer = Convert.ToInt32(results2.Attributes("IncidentNum"))
Error 1 'Attributes' is not a member of 'System.Collections.Generic.IEnumerable(Of
uggggggggggggggggg
