Legend with templates
782
01-12-2012 10:01 AM
arvinderbhalla
I am trying to implement the legend with templates sample
http://help.arcgis.com/en/webapi/silverlight/2.1/samples/start.htm#LegendWithTemplates
The legend control is missing the tree expansion button. any ideas??
Arvinder
DominiqueBroux
Esri Frequent Contributor
The default legend template use a tree view (except WinPhone version) and so the tree expansion buttons should appear.
Check the following points:
  1. That there is no legend implicit style defined in your application (likely in app.xaml) that might change the legend template
  2. That your legend doesn't point to a style that might change the legend template
  3. That there is no TreeView implicit style in your application that might change the tree view expansion button
