Legend TOC from Template, Checkbox not working!
1958
10-03-2012 02:52 PM
Jitendrudulacaraju
Silverlight 4 application. Made legend templates. The Checkbox on the TOC module is not working. here is the xaml code for the template:
<DataTemplate x:Key="LayerTemplate">
        <StackPanel  Margin="0,-1" Orientation="Horizontal">
            <ToolTipService.ToolTip>
                <StackPanel MaxWidth="400">
                    <TextBlock FontWeight="Bold" Text="{Binding Layer.ID}" TextWrapping="Wrap" />
                    <TextBlock FontWeight="Bold" Text="{Binding Label}" TextWrapping="Wrap" />
                    <TextBlock Text="{Binding Description}" TextWrapping="Wrap" />
                    <TextBlock Text="{Binding SubLayerID, StringFormat='SubLayer ID : {0}'}" />
                </StackPanel>
            </ToolTipService.ToolTip>
            <Grid>
                <!--<CheckBox IsChecked="{Binding IsEnabled, Mode=TwoWay}" VerticalAlignment="Center"/>-->
                <CheckBox Content="{Binding Label}"  IsChecked="{Binding IsEnable, Mode=TwoWay}"
                          IsEnabled="{Binding IsInScaleRange,Mode=TwoWay}" IsHitTestVisible="False" VerticalAlignment="Center"/>
            <!--<TextBlock Text="{Binding Label}" VerticalAlignment="Center"/>-->
            </Grid>
        </StackPanel>
    </DataTemplate>
DominiqueBroux
Esri Frequent Contributor
Setting IsHitTestVisible to false prevents any input from the mouse or the keyboard.
Set it to true or keep the default value instead.
Jitendrudulacaraju
Ok , done that. But Now I want to turn on / off several sublayers within a Map service layers from the TOC. I can check/uncheck the button, but it does not change the visibility of the layer.
DominiqueBroux
If your map service is cached, you can't change the visibility of the sublayers. The reason being that the image are pregenerated at the server side with the visibilities defined by the service.
The workaround might be either to create a non cached service or to create one cached service by layer (or by group of layers you want to manage together).
Though, both solutions have performance impacts.
Jitendrudulacaraju
I did make one caches service by layer(s), that is turn off or on all together. But to manage each sub layer individually under a map service layer, I should be serving up a non cached layer, am I right ?
DominiqueBroux
Right. Cached map services don't support changing sublayers visibility.
