Issues with Spatial Query
720
05-20-2010 08:21 AM
AndresOsorio
Hi
I´m having a problem now with the spatial query. When i select the point or Polyline tool to make a selection on my dynamiclayers, those only work with dynamiclayers that have a Polygon geometry. If you try layers with point or line geometry it doesn´t seems to work.
If anybody knows the way to fix this problem, solve it, deal with it...
Thanks.
Andres Osorio
BedaKuster
if you make a spatial query with a MapPoint, this MapPoint must be in the Geometry you want to query. So you can try very long until you reach the correct location to query another MapPoint in your service 😉
1:
You could use a IdentifyTask. There you can specify a tolerance for your MapPoint. But you can't specify a definitionquery, so sometimes you can't use this.
2:
You can make an Envelope out of your MapPoint,
Envelope e  = new Envelope();
e.XMax = mappoint.x + 100;
e.XMin = mappoint.x -100;
e.YMax = mappoint.y + 100;
e.YMin = mappoint.y - 100;
and then specify this new envelope as querygeometry.
not very nice, but works for points.
3:
for polylines, try to set the spatialRelationship to Crosses or something other than Contains. I didn't try it but it should work on this way.
hope it works
