issues passing map properties from SL to a WCF service
1618
08-04-2011 08:35 AM
TerryGiles
Hi all,
I'm working on a custom ID tool to work against WMS layers in my map.  I've set up a WCF service to do most of the work but when I pass in an object (FeatureInfoParams, definition below) only the string/int properties are populated, I lose the objects (ESRI Envelope, System.Windows.Point, & System.Windows.Rect).  What do I need to change in my class to get these from the client to the server?
Thanks,  Terry
server side -
side question - If I do not mark the WMSQuery class with the [XmlSerializerFormat] attribute I get a generic "Communicators error - Not found" when I call the GetFeatureInfoAsynch client side.  Anyone know why?
namespace AWEMap.Web
    [ServiceContract(Namespace = "AWEMap.Web")]
    [AspNetCompatibilityRequirements(RequirementsMode = AspNetCompatibilityRequirementsMode.Allowed)]
    public class WMSQuery
        [OperationContract]
        public void GetFeatureInfo(FeatureInfoParams FIParams)
            WebClient web = new WebClient();
            string strGetFeat = FIParams.Url + "?REQUEST=GetFeatureInfo&SERVICE=WMS&VERSION=" + FIParams.Version;
            strGetFeat += "&Layers=" + FIParams.Layers;
            strGetFeat += "&STYLES=default&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE";
            strGetFeat += "&BBOX=" + FIParams.Extent.XMin + "," + FIParams.Extent.YMin + "," + FIParams.Extent.XMax + "," + FIParams.Extent.YMax;
            strGetFeat += "&WIDTH=" + FIParams.Map.Width + "&HEIGHT=" + FIParams.Map.Height;
            strGetFeat += "&QUERY_LAYERS=" + FIParams.Layers;
            if (FIParams.Version == "1.3.0")
                strGetFeat += "&CRS=EPSG:" + FIParams.SRID;
                strGetFeat += "&I=" + FIParams.Point.X + "&J=" + FIParams.Point.Y;
            else
                strGetFeat += "&SRS=EPSG:" + FIParams.SRID;
                strGetFeat += "&X=" + FIParams.Point.X + "&Y=" +  FIParams.Point.Y;
            ...... more code here to handle XML returned by webclient....
  [DataContract(Namespace = "AWEMap.Web")]
    public class FeatureInfoParams : INotifyPropertyChanged
        public event PropertyChangedEventHandler PropertyChanged;
        public FeatureInfoParams() { }
        private string _url;
        private string _version;
        private string _layers;
        private int _srid;
        private Envelope _extent;
        private Rect _map;
        private Point _point;
        [DataMember]
        public string Url
            get { return _url; }
            set { _url = value; NotifyPropertyChanged("Url"); }
        [DataMember]
        public string Version
            get { return _version; }
            set { _version = value; NotifyPropertyChanged("Version"); }
        [DataMember]
        public string Layers
            get { return _layers; }
            set { _layers = value; NotifyPropertyChanged("Layers"); }
        [DataMember]
        public int SRID
            get { return _srid; }
            set { _srid = value; NotifyPropertyChanged("SRID"); }
        [DataMember]
        public Envelope Extent
            get { return _extent; }
            set { _extent = value; NotifyPropertyChanged("Extent"); }
        [DataMember]
        public Rect Map
            get { return _map; }
            set { _map = value; NotifyPropertyChanged("Map"); }
        [DataMember]
        public Point Point
            get { return _point; }
            set { _point = value; NotifyPropertyChanged("Point"); }
        public void NotifyPropertyChanged(string propertyName)
            if (PropertyChanged != null)
                PropertyChanged(this, new PropertyChangedEventArgs(propertyName));
client side
                        WLyr = (_Map.Layers as WmsLayer);
                        WMSQueryService.WMSQueryClient client = new WMSQueryService.WMSQueryClient("RelativeBinding_WMSQuery");
                        WMSQueryService.FeatureInfoParams fip = new WMSQueryService.FeatureInfoParams()
                            Url = WLyr.Url,
                            Extent = _Map.Extent,
                            Layers = string.Join(",", WLyr.Layers),
                            Map = new System.Windows.Rect(0, 0, _Map.Width, _Map.Height),
                            Point = new Point(_Map.MapToScreen(ptMapPoint).X, _Map.MapToScreen(ptMapPoint).Y),
                            SRID = _Map.SpatialReference.WKID,
                            Version = WLyr.Version
                        client.GetFeatureInfoAsync(fip);
PatrickBrooke
I don't have the code samples to show you, but you will have to serialize those objects. For example, I sent a png image, awhile back for client to server, and I had to convert it to a string (Base64). I have a sample of how to do that to an image. Basically, you need to convert all of those values to int or string to send them through WCF.
I know this is not s silver bullet solution, but I hope the logic is helpful.
byte[] byt = System.Text.Encoding.UTF8.GetBytes(strOriginal);
    // convert the byte array to a Base64 string
    strModified = Convert.ToBase64String(byt);
PatrickBrooke
Also, this is actually closer to what you are doing:
http://weblogs.asp.net/albertpascual/archive/2009/04/06/serializing-json-geometry-objects-between-si...
Same rule applies, you must serialize objects to string/json/html or whatever when send through WCF.
TerryGiles
Thanks Patrick I saw that blog earlier today too.  In the end I changed from trying to pass the objects to just passing their properties I needed (point.X map.Width, etc..) as primative types (string, double, etc...).
Also found a good summary of what works with the DataContractSerializer from Microsoft here - http://msdn.microsoft.com/en-us/library/cc656732.aspx
