IP addresses of some services?
4564
03-04-2015 01:26 AM
AnatoliiTerentiev
Dear Gurus!
To configure the firewall I should specify the addresses on the Internet, which I needed for my silverlight project.
When I use next code:
<esri:Map x:Name="myMap" Background="White" WrapAround="true"
          Extent="3200000,8500000,4250000,10130000">
            <esri:OpenStreetMapLayer ID="OSMLayer" Style="Mapnik" />
</esri:Map>
the program hangs .I suppose that the service is unreachable perhaps due to the firewall in the enterprise. How do I find out the addresses, requied for services?
DominiqueBroux
Esri Frequent Contributor
I would recommend you to use fiddler to look at requests sent to the servers.
For OpenStreetMapLayer, the servers are depending on the style.
For Mapnik style, the servers are  http://<domain>.tile.openstreetmap.org with domain equals a, b or c.
You can get the current IP addresses of these servers but I would not rely on them for configuring your firewall since nothing prevent these IP from being changed.
DominiqueBroux
AnatoliiTerentiev
Thank you, Dominique!
I thought about fiddler or fireshark.
P.S. All works.
