Intallation error
8436
22
07-22-2010 02:00 PM
JasGT
Hi all,
I can't install ArcGIS API for Microsoft Silverlight/WPF 2.0, the intall send this message: Installation ended prematurely because of an error. I have windows 7 Home Premium 64 bits, VS 2010 ultimate, Microsoft Expression 4 and I'm try download the exe many times and can't install, help.
patroam
1. With the application already installed I get to the "Application Maintenance" screen. On any of the choices clicking Next causes the fatal error.
2.  Yes.
3.  Yes
4.  No
5.  ArcGIS API for Microsoft Silverlight�?�/WPF�?� version 2.0
Pat
Thanks for the log.  A couple questions�?�
1)    In the setup, do you get to the panel that shows the license agreement?
2)    Have you tried unblocking the exe?  (right click, go to properties > General tab, click Unblock)  If not, try it and see if you�??re able to run through the setup.
3)    Have you tried explicitly running the exe as an administrator?  (right click, select �??Run as administrator�?�)
4)   Did you have ArcGIS Silverlight/WPF 1.x installed on this machine in the past?
5)  What ESRI products do you have installed currently?
KelceyCasson
I've got the same problem (error on install, same error listed), but I'm running 32-bit Windows 7.
I've also got the Silverlight API 1.1 installed on my system and am getting the same error when I try to uninstall it ... I'll try to get you a log file later today.
MarkStoren
I also encountered the same error trying to install on Windows 7.  It can be worked around by running the installer from the command line using the following:
msiexec.exe /i "c:\users\<name>\appdata\local\temp\arcgis api for microsoft silverlight-wpf x86\v2.0\setup.msi" /qr+
