'InitializeComponent' is not declared
1219
01-06-2011 09:48 AM
ElizabethMiller
Like others on this list I am trying to set up a basic map using the sample code and am getting many errors of this nature (i.e." 'InitializeComponent' is not declared," "'MyMap' is not declared," etc.) When I mouse over the errors in Visual Web Developer 2010Express, I get the error correction option hints that list the name of my project twice, for example:
"Generate method stub for 'InitializeComponent' in 'SilverlightApplication.SilverlightApplication.MainPage'"
Why is this happening and how can I restructure my project so that these connections link up properly?
Thanks for your help!
DominiqueBroux
Esri Frequent Contributor
If you are using VB, it's probably the same error than this described in this thread : http://forums.arcgis.com/threads/11700-InitializeComponent-is-not-declared-Expression-Blend-Error?p=...
