Infowindow going out side the parent control
1903
6
05-21-2012 04:59 AM
JobyGeorge
I have added an infow window in my silverlight application to show the details of the location. Its working normally,But when i move the map with this info window open it goes over the parent control which holds the map. Is there any way to getrid of it?
Please help.
regards,
Joby.
DominiqueBroux
Esri Frequent Contributor
The next version (3.0 release) will take care of that out of the box.
If you want to implement the functionality by yourself in the current version,  this Rex's blog post might help : http://blogs.esri.com/esri/arcgis/2010/10/01/how-to-keep-maptips-in-the-map/
vipulsoni
Please help.
regards,
Joby.
I am having the same problem and tried to control the behavior by removing the infowindow if the mouse is going out of the map control. but while panning the map the mouse is inside the map control and infowindow then comes on top of other controls on edges of the map.
DominiqueBroux
JobyGeorge
Is there any property in InfoWindow by setting which we can disable this?
Joby
JobyGeorge
Can you please send me the exact link?
Joby
DominiqueBroux
The link looks good to me:confused:
h t t p://blogs.esri.com/esri/arcgis/2010/10/01/how-to-keep-maptips-in-the-map/
JobyGeorge
Sorry, When I clicked first time it goes somewhere else now only got the correct page.
Joby.
