IdentifyResults.Value
666
08-04-2010 08:04 AM
JamesS1
When performing an identify using Silverlight API, how do you define which field is used for the IndetifyResult.Value property?
ChristopherHill
The IdentifyResult.Value contains the data from DisplayField defined by the Rest service. You cannot change what field is used in the API directly.
JamesS1
Thanks. If anyone is interested, the display field can be changed in Properties >> Display for a layer within ArcMap. This change will be reflected when doing an identify using the Silverlight API.
