Identifying the clicked path/ring
1071
03-07-2011 10:58 PM
BrianBorg
I have a number of polyline/polygon geometries and each contain more than one path/ring. When i capture the mouse click event, it returns the whole feature. Is there a way how I can get the actual path/ring clicked rather than the whole feature?
DominiqueBroux
Esri Frequent Contributor
There is nothing out of the box.
I guess this might be developed by using the Paths and Rings properties of the polyline/polygon but likely not that easy (this would need some geometry calculations).
DanielWalton
Below is some code to do this. The only gotcha is to somehow make sure that overlapping rings are parsed smallest->biggest, to ensure you get the most accurate result.
        void graphicsLayer_MouseLeftButtonUp(object sender, GraphicMouseButtonEventArgs e)
            var clicked = Map.ScreenToMap(e.GetPosition(Map));
            var polygon = (Polygon)e.Graphic.Geometry;
            foreach(var ring in polygon.Rings)
                if (Intterra.Projection.Utilities.PointIsInGeometry(ring, clicked))
                    //you found the correct ring
        static bool PointIsInGeometry(PointCollection points, MapPoint point)
            int i;
            int j = points.Count - 1;
            bool output = false;
            for (i = 0; i < points.Count; i++)
                if (points.X < point.X && points.X >= point.X || points.X < point.X && points.X >= point.X)
                    if (points.Y + (point.X - points.X) / (points.X - points.X) * (points.Y - points.Y) < point.Y)
                        output = !output;
                j = i;
            return output;
DanielWalton
A better approach would be to split each polygon with multiple rings into multiple graphics, each one having a single ring.
        void Graphics_CollectionChanged(object sender, NotifyCollectionChangedEventArgs e)
            if (e.Action != NotifyCollectionChangedAction.Add) return;
            var gc = (GraphicCollection)sender;
            foreach (var item in e.NewItems)
                var g = (Graphic) item;
                if (!(g.Geometry is Polygon) || ((Polygon) g.Geometry).Rings.Count <= 1) continue;
                var p = (Polygon) g.Geometry;
                Dispatcher.BeginInvoke(() =>
                    foreach (var ring in p.Rings)
                        var newg = new Graphic {Geometry = new Polygon {SpatialReference = p.SpatialReference}};
                        foreach (var a in g.Attributes) newg.Attributes.Add(a);
                        ((Polygon)newg.Geometry).Rings.Add(ring);
                        gc.Add( newg );
                    gc.Remove(g);
