Identify Tool - Silverlight Examples
1668
6
04-06-2011 07:36 AM
BrandonIves
I am new to developing in silverlight and I am trying to go through the examples found in the resource center. I copied and pasted the code for the identify tool into VS2010 and I am getting an error on building the project:
"The type or namespace name 'IdentifyResults' could not be found (are you missing a using directive or an assembly reference?)
Did I miss a step somewhere? Am I missing a reference? I added all of the references that the example noted. Thanks for any input.
Here are the two examples I was using:
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#Identify
http://help.arcgis.com/en/webapi/silverlight/help/index.html#/Identify_task/01660000001m000000/
nakulmanocha
I am able to run the sample without any issues. What exactly is IdentifyResults? The only place it appears in the sample is args.IdentifyResults. I know there is IdentifyResult but I don't see IdentifyResults. Could you please attach your complete code here? Thanks
BrandonIves
Here is my code. Below I added an arrow to show the error.
using System;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Documents;
using System.Windows.Ink;
using System.Windows.Input;
using System.Windows.Media;
using System.Windows.Media.Animation;
using System.Windows.Shapes;
using ESRI.ArcGIS.Client;
using ESRI.ArcGIS.Client.Tasks;
using ESRI.ArcGIS.Client.Symbols;
namespace IdentifyExpressionBlend
public partial class MainPage : UserControl
----------------> private List<IdentifyResults> _lastIdentifyResult;
public MainPage()
// Required to initialize variables
InitializeComponent();
// Do identify when Map is clicked
private void MyMap_MouseClick(object sender, ESRI.ArcGIS.Client.Map.MouseEventArgs args)
// Show an icon at the identify location
GraphicsLayer graphicsLayer = MyMap.Layers["IdentifyIconGraphicsLayer"] as GraphicsLayer;
graphicsLayer.ClearGraphics();
ESRI.ArcGIS.Client.Graphic graphic = new ESRI.ArcGIS.Client.Graphic()
Geometry = args.MapPoint,
Symbol = IdentifyLocationSymbol
graphicsLayer.Graphics.Add(graphic);
// Identify task initialization
IdentifyTask identifyTask = new IdentifyTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/" +
"Demographics/ESRI_Census_USA/MapServer");
identifyTask.ExecuteCompleted += IdentifyTask_ExecuteCompleted;
identifyTask.Failed += IdentifyTask_Failed;
// Initialize Identify parameters. Specify searching of all layers.
IdentifyParameters identifyParameters = new IdentifyParameters();
identifyParameters.LayerOption = LayerOption.all;
// Pass current Map properties to identify parameters
identifyParameters.MapExtent = MyMap.Extent;
identifyParameters.Width = (int)MyMap.ActualWidth;
identifyParameters.Height = (int)MyMap.ActualHeight;
// Identify features at the click point
identifyParameters.Geometry = args.MapPoint;
identifyTask.ExecuteAsync(identifyParameters);
// Populate ComboBox with results when identify is complete
private void IdentifyTask_ExecuteCompleted(object sender, IdentifyEventArgs args)
IdentifyComboBox.Items.Clear();
// Check for new results
if (args.IdentifyResults.Count > 0)
// Show ComboBox and attribuets DataGrid
IdentifyResultsStackPanel.Visibility = Visibility.Visible;
// Add results to ComboBox
foreach (IdentifyResult result in args.IdentifyResults)
string title = string.Format("{0} ({1})", result.Value.ToString(), result.LayerName);
IdentifyComboBox.Items.Add(title);
// Workaround for ComboBox bug
IdentifyComboBox.UpdateLayout();
// Store the list of identify results
_lastIdentifyResult = args.IdentifyResults;
// Initialize ComboBox and fire SelectionChanged
IdentifyComboBox.SelectedIndex = 0;
else
// Hide ComboBox and attributes DataGrid and notify user
IdentifyResultsStackPanel.Visibility = Visibility.Collapsed;
MessageBox.Show("No features found");
// Show geometry and attributes of selected feature
void IdentifyComboBox_SelectionChanged(object sender, SelectionChangedEventArgs e)
// Clear previously selected feature from GraphicsLayer
GraphicsLayer graphicsLayer = MyMap.Layers["ResultsGraphicsLayer"] as GraphicsLayer;
// Check that ComboBox has a selected item. Needed because SelectionChanged fires
// when ComboBox.Clear is called.
if (IdentifyComboBox.SelectedIndex > -1)
// Update DataGrid with selected feature's attributes
Graphic selectedFeature = _lastIdentifyResult[IdentifyComboBox.SelectedIndex].Feature;
IdentifyDetailsDataGrid.ItemsSource = selectedFeature.Attributes;
// Apply symbol and add selected feature to map
selectedFeature.Symbol = SelectedFeatureSymbol;
graphicsLayer.Graphics.Add(selectedFeature);
// Notify when identify fails
private void IdentifyTask_Failed(object sender, TaskFailedEventArgs args)
MessageBox.Show("Identify failed: " + args.Error);
nakulmanocha
The List class is available within System.Collections.Generic namespace.
You need to add the following as one of your using statements
using System.Collections.Generic;
BrandonIves
I actually do have "using system.collections.generic;" as a using statement. Not sure why it didn't paste. I litterally copied and pasted the code and then added additional Using Statements. I took a screenshot to show the error.
ChristopherHill
the class is IdentifyResult not IdentifyResult(s) you added an "s" to the end. ^_^
BrandonIves
Doh. Good eyes, thank you so much. Thanks to nmanocha also!
