Identify Task issues
11895
25
04-13-2010 08:40 AM
AngelGonzalez
I am using the ESRI sample for Identify and got a problem. I have a sublayer list with about 13 layers. Only the first 4 are set to be visible when the silverlight app is first run. The identify Task works fine with these first 4 layers. When I click on the checkbox to make another layer visible and use the Identify tool the fifth layer does not appear on the identify tool. Yet when I go back and update the mxd to make the fifth layer visible and reboot my ArcGIS server (the refreshing of a service to pickup and any changes made to the mxd is not being pickup by Silverlight app, only a reboot will do this , bug??) the identify tool picks up the the fifth layer.
Does the Identify task works with sublayer list? Do I need to refresh something?
I am using SL3 with ESRI 1.2 SL API
Angel
JenniferNery
LayerOption, by default is Top. You can specify this in the IdentifyParameters http://help.arcgis.com/en/webapi/silverlight/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.Tasks.Iden...
I have to check with the ArcGIS Server team about the Index out of bounds error. I'll get back with you on that.
JenniferNery
Here's what I've gathered -
You need to fix your service and have every ID match their index.
I was told that top:5 may actually be accessing ID=6, that's why it worked and top:6 is trying to access ID=7, which is already out of bound... as caused by the broken layer (ID=1).
ID=1 may be missing because it was not published but is still contained in your ArcMap Table of Contents. You can either delete layer with ID=1 from ToC or include it and re-publish.
MatthewPilgrim
Jennifer thanks again for your time,
This would suggest an issue in the implementation.  Has this be raised as a 'bug'?
I'm not sure this is true.  I have tried id 0 and id 5.  They both return features from the correct layer (id/name).
I will talk to the map admin, alternatively I may have to return features from all layers and sort them on the client - not ideal.
Regards,
Matt
JenniferNery
Oh, if ID=5 returns the correct layer, then I really don't know what could be wrong with ID=6.
Have you tried using the same parameters on your web browser? Same error? If yes, I can only suspect that there's something wrong with that layer.
MatthewPilgrim
I get the same results in the browser.
Could someonone ate ESRI replicate the situation (i.e. index != id and max id > layer count) at confirm this as a bug (or not).
Many thanks,
Matt
JenniferNery
I forwarded your question to the REST API team. You can post to their forum too http://forums.arcgis.com/forums/11-ArcGIS-Server-REST-API or go through support http://support.esri.com/en/
